I know this subject has been thrashed to pieces over the years, and I've read everything on here I could find....but I haven't seen anything new out there for a bit, and hoping there is some more definitive answers to the age old question of oil control.
Bit of back ground, My car is about 700hp, built RB30 GT-R with standard cam baffles, a shit little Greedy catch can, and a RIPS extended sump and a Nitto oil pump, I also have a head drain going to the top of the sump on the drivers side.
I took the car out to the track over Xmas for a blat around on wide 18" S/H slicks, and as it did the last time, it fired a shit tonne of oil out the catch can breather under the car and bought up the low oil pressure light at least four times around each lap, I have looked over the data log from the ECU, and it's not too bad where it mostly does it (low throttle position) but there are areas that it isn't so good.
Normal driving around town and fast blats the country hardly puts anything into the catch can, it's just moisture and a little bit of oily sludge, that's fine, but on the track with the increased revs and high G's it's a completely different story. I know the catch can is rubbish, and that is the first thing on the list to get built, but it is still going to fill it if I can't keep the oil in the engine.
So......Mines (or Hi Octane) Cam Baffles, are they going to help to keep the oil from firing out of the breathers?
Catch Can design.......Baffles? Sump return? Steel wool? Head drains?
Accusumps.....is this going to help with the low pressure areas around the track? Will I need one of the electronic valves?
In a perfect world, Dry sump is the answer, but I can't quite run to that :(
Any good answers would be good.
Cheers,
Chris.
Edited by Sub Boy32
I would have thought the RIPS sump would have had a) enough capacity and b) decent enough baffling to prevent that? 9 litres or so of oil is a huge amount of oil in an engine. I would definitely put an Accusump on at least as a bit of a patch up for now as it will potentially save your engine when you do get oil surge. It will only be a patch up to a degree. If the oil returns in the head to the sump weren't done (enlarged) when the engine was built then it it always going to be a battle to get the oil back to the sump. With your catch can the issue would be more the setup of the lines rather than the can itself. Make sure it's plumbed correctly. Rocker cover baffles will definitely slow the rate of oil getting into your catch can and might give you a bit more track time before the oil level gets low enough to get surge.
My recommendation- Accusump for now to help your engine live a bit longer then when the engine comes out next time (inevitable if you're seeing the oil light a bit!) then get everything else sorted (head oil returns, restrictors (no mention of if this was done?), plus all other recommendations out of the Oil Control thread.
I would have my sump breather* plumbed straight into the catch can along with the rocker breathers. Have your Catch can vented to atmosphere with large diamater filter. Id say my catch can is just under the volume of a tissue box
* the line from your sump to your rockers is NOT an oil return for your head, it is simply a vent for relieving pressure from your crankcase. You need to relieve this pressure as quickly as possible as it will reduce your oil flow through the block back to your sump
The only way that line would act like a drain is if your head had a fek load of oil flow (aftermarket pump) with no oil restrictor in your block, in which case you would be Fecked anyway.
Cheers guys, yeah I have read all of the oil control thread, the last ten pages as pointed out are prob the most informative bit for what I need, just was making sure there wasn't any thing else I was missing. I didn't see much in there regarding baffling of the catch can, but I'll have another read to see if I've missed anything.
I know the "head drain" is not really a drain, but that's what it seems to be called.
I do have a 1.5mm restrictor in the block, but never got the drains drilled.
sounds like you have oil cooling problems. crank case pressure would not flicker you oil light at low rpm.when u have excess pressure that pressure relief itself usually out your breather or passes through ya rings and is seen as oil burning through your exhaust as black smoke which makes the car looks like its running rich.. when the oil heats up and thins out you would get a significant drop in oil pressure ..as long as the oil is over heating your gona get this issue.....i run 500hp in a s15 and have no oil restriction, no catch can but i did start suffer from oil starvation after 300hp ..when the power came on my oil pressure went from 70 to 40 psi .i installed a custom extended sump with baffles and a oil cooler and run a lil over 9L of oil and dont have that issue anymore.
you wouldn't see the oil pressure drop during normal driving because the oil cooling system your using now is sufficient enough to keep the oil cool for couple pulls here and there.track is another issue constant rpm over 6k and a lot of rpm limiter will heat stuff up a lot quicker than u think..
my 650hp integra throws out a bit of oil after a couple passes at the track .its normal to do that with any engine at that power....but a drop in oil pressure significant enough to bring on the light is a different problem..
what grade oil are u using and what oil cooler?
With the oil pressure light I don't mean the factory light, it is one on my RacePak IQ3. I'm running a oil pressure sensor that is hooked to the Link ECU and the light goes off at 100kpa
I don't think it will be an oil heat issue as I have a Link oil temp sensor hooked to the dash, and a large oil cooler, it never goes above 90deg, I run Redline Race 40, and there is about 8ltrs of it in the extended sump.
40 weight oil, Nitto oil pump and 1.5mm restricer sounds wrong.
Id be running a 50 weight if your clearances are large enough with a 1.1mm restrictor, reduces the amount of oil going up, that needs to go back down again.
Sump breather fittings and catch can setup is very important, you need to get the blow by out of the sump, without allowing it as best as possible to go up and breath out of the rocker covers as it will take oil with it.
If you pull off your sump to head breather, is there alot of oil residue in there? the pipe that is
You can set the link to cut the engine if oil pressure goes below a predetermined level at x revs etc.
A 1.0mm restrictor would be better at keeping more oil in the sump.
Attached is a (very) rough drawing of my catch can baffles and beside it a better designed baffle system (beyond my capabilities but easy for Robbie).
Actually you could just have a series of horizontal plates (round or square depending on the shape of the catch can) with holes cut in them with a tube running from a hole in the bottom plate to the outlet.
As has been said the oil thread has answers.
The difference between the track and the road is you dont get time on the track for the oil to return out of the head - something which requires an absence of blow by. As for the catch can I dont know why you cant get a can modelled after the cyclones that the rest of the civilised world uses for separation. Havent ever seen one.
http://en.m.wikipedia.org/wiki/Cyclonic_separation
Will get around to fixing mine in that manner one day.
Edited by djr81
Sorry, typo, it is a 1.2 restrictor, cheers but I'm going to stick with the 40wt oil. I will use both of the sump breathers on the new catch can design as it seems to be the common answer in this and the oil control thread.
I will have to check on the head breather pipe if there is any oil residue in it.
Thanks for the sketchs of the catch can baffles, that is how I thought is would plumb up. Do you put any stainless wool in it anywhere?
Yeah a cyclone can would be cool, you could perhaps cut a hole under the battery box (R32) and run it down into the guard to get the height required?
My vent on the sump was below the oil line and oil was forced up the breather line into the head to the catch can and then all over the engine/ground/track.
A one way valve on the vent fixed the issue.
Is your fitting on the sump below oil line?
Sadly mine weren't, mine were meant to be drains but as we all know now that's not how it works.
When we disconnected the fitting at the head and spun it up on the dyno it was like a hose vomiting oil.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
