i got myself a skyline and await delivery of it from japan in 8-10weeks i am after some answers and suggestion for mods to put on my car.
are there power gains with the following
a power fc
adjustable cam gears or are they a redundant item just to look good..?
any help or suggestions would be greatly appreciated...
by the way it is a bnr32 gtr...
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/
First and most significant mods should be a new exhaust then the power FC. You will find quite significant gains for "relatively" little expence. Make sure you get them done in that order otherwise the power FC will have to be retuned after the exhaust install.
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-922616
thanks i kinda jumped the gun there i will wait till i have it in my drive way and see what the mechanic says about the engine and what needs to be fixed and or replaced and how much i will be hit for re doing the trim on the seats and door trims. I go from there...will see what is left over from that and.....
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-926230
Dont get new cam gears, they are mainly for looks. Get the Actual Cam.
Cam gears for looks? If they are under a dust cover (like they should be) no one is going to see them. Adjustment to camshaft timing with adjustable cam gears is very important when going to the finest detail of engine tune. Race engines do not have them on for looks.
A Cam gear will cost around $150 or so, only need one for the exhaust side. It's typical to see 10rwkw increase through the power band from retarding the exhaust cam timing 4 degrees. Fitting one is a 30min job and if you know the right SDU people or are handy with the spanner, it's free. The base ignition timing will need an adjustment and the AFR will benifit from a check also. Should be at worst a little time on the dyno for a tune ($100). All up $250 = 10rwkw.
Regarding the cam shaft change it will cost upwards of $600 a camshaft, It's $800 odd to fit and retune. The gains may be as much as 15-25rwkw on a fairly standard motor with the right sized camshafts. All up $1400+ = 15-25kw.
Depends on your budget. The cam gear is a bargain mod.
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-931911
  • 4 weeks later...
Hi guys, im in the same boat as loz, except im ive got a r33 gtst on its way..
Need advice on power upgrades - major and minor including new turbo etc...
The car is STOCK :D
Also need advice on mod stages, what goes where in the timeline...im a newbie
If there is a link with the info on thats already been posted.. that would b great, and would save alot of time..
Thanks guys
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-976365
Ok if ya goin to get an exhaust done spend the extra $$$ and get it from turbo back, ie ask for the dump and down pipes to be done..... please make sure you go to a reputable workshop to get that done... don't go to "She'll be right ABC mechanics" look at outr sponsors page perhaps, dump & down pipe gave me 20 rwhp increase.. off a single turbo if its a twin turbo well i'd say you may get a bit more of an increase! then yeah go the cam gear and power FC.
Both me and Rev210 placed our order together if memory serves me correct :-) we got the HKS cam gear both of us were happy with the $$$ to performance gain!
Go to the forced induction area or do a search on "mods" or sumfin similar....
Or drop Rev210 100's of PM's he loves that stuff! HAAHAH!!
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-976476
lucky you get your line so soon, mine wont be here till mid oct!
anyways, first thing i do to any car i get is get it completly serviced, change everything that can be changed e.g all fluids, brake pads etc etc.
make sure she runs sweet, then start with some modding!!
can anyone reccomend a good service workshop?
steve
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-976563
Thanks guys for all the help.. put me on the straight and narrow hehe
umm Phatr32 give us a msg when u get your r32 skyline..
ill be saving till I can afford the mods and i was thinking maybe we might get discount if we go in and buy our mods together in a package? up 2 u though...
also depends wat u want obviously and where u want it from and who fits it...
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-976656
If money is an issue then definietly: Exhaust/air filter/re-mapped factory ecu (these are pretty good)/boost control (12-14psi). This is relatively inexpensive and will drive very nicely and capable of 12's. Only other consideration would be a heavy duty clutch.
Re-mapping is quite a new thing here in WA for the r33 gtst... sr20's are quite common and Lumpy at hyperdrive does em....
Who remapps the r33 gtst ecu? wasn't there something with the EPROM on there? apparently it is very hard to do???? I haven't heard of many remapped gtst ECU's in perth.... i could be wrong but if anyone has had theres done leme know what it;s like and what gains.....
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-976709
bunch of 32's have been repapped using the rom tuning technology speedworks have, the issue with r33's is they use a flash style memory which can be tuned via the console port, the japs have the bits to do it, but no one here has yet developped it..
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-977053
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
    • Rear turbo is leaky, most likely at the oil drain. From what I could see with my boroscope it seemed to have seeped out at the very top of that return hose. Is it possible that the oil climbs up that hose to then leak out? Yup, coolant leak on the hot side of the engine, only noticed after seeing clear rusty residue in the block right from the turbo oil feed downwards to the pan, and red droplets hanging from the pan. No clear sign yet from where it comes, and most of the lines there are hardlines right? Last year, seeing those red drops, I thought it was power steering, will be glad if that is not leaky at least. Another leaking hose I found by chance is the lower of the two heater core hoses coming from the firewall to the back of the head. That one is not too bad to get to if I have to replace.
    • I think for response I'm already kind of out there no? he -5s are not the best pick for that as the Internet tells me. Maybe I should switch to -7s while I still can? Though that almost definitely warrants an engine pull along with the other issues I have.
    • Which I agree with. I don't want or need a high hp straight line car, I want it to be fun on the road and nothing more. Hence why I said my max power goal will be around 500 crank. The few times I drove the car last year I didn't even use high boost and it was already quick enough for me, should have been around 380-400 crank I think (2860-5s at 1-1.1bar).
