i got myself a skyline and await delivery of it from japan in 8-10weeks i am after some answers and suggestion for mods to put on my car.
are there power gains with the following
a power fc
adjustable cam gears or are they a redundant item just to look good..?
any help or suggestions would be greatly appreciated...
by the way it is a bnr32 gtr...
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/
First and most significant mods should be a new exhaust then the power FC. You will find quite significant gains for "relatively" little expence. Make sure you get them done in that order otherwise the power FC will have to be retuned after the exhaust install.
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-922616
thanks i kinda jumped the gun there i will wait till i have it in my drive way and see what the mechanic says about the engine and what needs to be fixed and or replaced and how much i will be hit for re doing the trim on the seats and door trims. I go from there...will see what is left over from that and.....
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-926230
Dont get new cam gears, they are mainly for looks. Get the Actual Cam.
Cam gears for looks? If they are under a dust cover (like they should be) no one is going to see them. Adjustment to camshaft timing with adjustable cam gears is very important when going to the finest detail of engine tune. Race engines do not have them on for looks.
A Cam gear will cost around $150 or so, only need one for the exhaust side. It's typical to see 10rwkw increase through the power band from retarding the exhaust cam timing 4 degrees. Fitting one is a 30min job and if you know the right SDU people or are handy with the spanner, it's free. The base ignition timing will need an adjustment and the AFR will benifit from a check also. Should be at worst a little time on the dyno for a tune ($100). All up $250 = 10rwkw.
Regarding the cam shaft change it will cost upwards of $600 a camshaft, It's $800 odd to fit and retune. The gains may be as much as 15-25rwkw on a fairly standard motor with the right sized camshafts. All up $1400+ = 15-25kw.
Depends on your budget. The cam gear is a bargain mod.
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-931911
  • 4 weeks later...
Hi guys, im in the same boat as loz, except im ive got a r33 gtst on its way..
Need advice on power upgrades - major and minor including new turbo etc...
The car is STOCK :D
Also need advice on mod stages, what goes where in the timeline...im a newbie
If there is a link with the info on thats already been posted.. that would b great, and would save alot of time..
Thanks guys
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-976365
Ok if ya goin to get an exhaust done spend the extra $$$ and get it from turbo back, ie ask for the dump and down pipes to be done..... please make sure you go to a reputable workshop to get that done... don't go to "She'll be right ABC mechanics" look at outr sponsors page perhaps, dump & down pipe gave me 20 rwhp increase.. off a single turbo if its a twin turbo well i'd say you may get a bit more of an increase! then yeah go the cam gear and power FC.
Both me and Rev210 placed our order together if memory serves me correct :-) we got the HKS cam gear both of us were happy with the $$$ to performance gain!
Go to the forced induction area or do a search on "mods" or sumfin similar....
Or drop Rev210 100's of PM's he loves that stuff! HAAHAH!!
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-976476
lucky you get your line so soon, mine wont be here till mid oct!
anyways, first thing i do to any car i get is get it completly serviced, change everything that can be changed e.g all fluids, brake pads etc etc.
make sure she runs sweet, then start with some modding!!
can anyone reccomend a good service workshop?
steve
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-976563
Thanks guys for all the help.. put me on the straight and narrow hehe
umm Phatr32 give us a msg when u get your r32 skyline..
ill be saving till I can afford the mods and i was thinking maybe we might get discount if we go in and buy our mods together in a package? up 2 u though...
also depends wat u want obviously and where u want it from and who fits it...
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-976656
If money is an issue then definietly: Exhaust/air filter/re-mapped factory ecu (these are pretty good)/boost control (12-14psi). This is relatively inexpensive and will drive very nicely and capable of 12's. Only other consideration would be a heavy duty clutch.
Re-mapping is quite a new thing here in WA for the r33 gtst... sr20's are quite common and Lumpy at hyperdrive does em....
Who remapps the r33 gtst ecu? wasn't there something with the EPROM on there? apparently it is very hard to do???? I haven't heard of many remapped gtst ECU's in perth.... i could be wrong but if anyone has had theres done leme know what it;s like and what gains.....
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-976709
bunch of 32's have been repapped using the rom tuning technology speedworks have, the issue with r33's is they use a flash style memory which can be tuned via the console port, the japs have the bits to do it, but no one here has yet developped it..
https://www.sau.com.au/forums/topic/45282-skyline-mods-help/#findComment-977053
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
