Fs - Big Hp Rb26 Parts
Hey guys I have some parts for sale from an engine setup we built for a customer.
Selling due to going for a bigger setup.
The setup below made 554kw at all 4 tyres in an R34 GTR on 33psi and was an absolute animal on the street.
All parts are located in Smithfield NSW and can be shipped anywhere in Aus.
Buyers are more than welcome to have any parts inspected by whoever they trust.
1. Nitto 2.7L Stroker kit.
Billet crank which has been durafinished
Nitto I beam rods
Nitto/JE forged pistons (87mm with upgraded pins)
Never had a bearing failure, perfect condition.
RRP with the durafinished crank is just over $7500
Selling for $5500 ono
2. RB26 race spec cylinder head.
1mm oversize Supertech valves inlet and exhaust
Supertech bronze guides
Tomei springs
Tomei offset retainers
Tomei buckets
Tomei cam cap studs
Kelford 270 degree 10.5mm lift cams
Very heavily ported
Welded and reshaped combustion chambers
The head was recently serviced by Advanced Performance Machining.
Shim clearances are immaculate, sounds beautiful.
The replacement value of this cylinder head is around the 10K mark.
Selling for $6500 ono
3. Precision 6766 turbo setup to suit RB26
Precision 6766 ball bearing T3 turbine housing with V-band outlet and SP comp cover.
Powertune steam pipe turbo manifold
45mm Turbosmart gate
3.5" dump pipe
Screamer pipe and plumb back pipe (if you want it to be engineer-able)
Oil lines
Intake pipe and hot side intercooler pipe.
All exhaust parts ceramic coated
Asking $4000
  • 1 month later...
 Share
