Difficult to offer correct advice unless you supply full engine details.
Generally speaking, you should run the max gap possible and for a stock engine with decent coil packs that's 1.1mm.
Likewise heat range would be 5 or 6 for a standard engine.
Once power is increased, you may find ageing coil packs can't keep up with the increased combustion pressures and the easy fix is to reduce plug gap.
Wouldn't suggest less than 0.8mm. If it takes a really close plug gap to avoid blowing out the spark you should be looking to new coil packs.
Heat range usually alters a range per 100hp increase over stock and it's pretty easy to have a 200hp increase.
Cold starts could become an issue with very high heat range plugs.
Make sure your IGN timing is correct while you're at it.
  • Like 1
For that hp GTR-Joey is on the money, but with your new coil packs I'd go for 1.0mm and see how she performs.
Check the shop actually sells you the BCPR plugs.
Often they'll offer BKR which is the same plug but built to ISO standards and protrudes 2.5mm shorter.
With them you need to give the spring conductor on the coil pack a bit of a tug to ensure it reaches the tip of the plug.
Grab some nickel thread anti-seize and apply a match head dob to the thread of each plug.
Tighten the plugs to the correct torque. Too loose and you'll see carbon up the threads of your old plugs. (the most common cause for stripping plug threads in alloy heads)
Blow the valley area clean with compressed air before you start removing things.
Remove/re-fit spark plugs one at a time.
So easy to drop an item down an open plug hole and suddenly that 5-minute job becomes very expensive.
  • Like 1
Thx Boys. Luckily for me my mechanic friend will be doing the work, but will fill him in with all these tips.
Also picked up a fuel filter, wondering how easy are they to change in the R32 GTR?
  • 3 months later...
I'm reading this topic and it's great but anti-seize
Common! !!!!
You got to think that if you putting that stuff on ya threads you start to isolate the plug from ground !!
Your coil is powering the plug but can't discharge it properly so the it searching for ground ...... Now it will find ground eventually where you did not coat the thread with. Now it can be a possibility of it electrode erode ya head meaning stripping ya threads slowly.
So not a good idea
But if you really find the need to put some lubrication on it... use graphite powder. This stuff is highly conductive and it's a dry lubricant.
Also do not use copper anti-seize coz it's reactive with alloys and normal nickel (silver ) is not good coz it's got lithium grease (non conducting)
Just my 2c
Jiffo I agree with your comment and great tips apart the Anti-seize ;)
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
