Difficult to offer correct advice unless you supply full engine details.
Generally speaking, you should run the max gap possible and for a stock engine with decent coil packs that's 1.1mm.
Likewise heat range would be 5 or 6 for a standard engine.
Once power is increased, you may find ageing coil packs can't keep up with the increased combustion pressures and the easy fix is to reduce plug gap.
Wouldn't suggest less than 0.8mm. If it takes a really close plug gap to avoid blowing out the spark you should be looking to new coil packs.
Heat range usually alters a range per 100hp increase over stock and it's pretty easy to have a 200hp increase.
Cold starts could become an issue with very high heat range plugs.
Make sure your IGN timing is correct while you're at it.
  • Like 1
For that hp GTR-Joey is on the money, but with your new coil packs I'd go for 1.0mm and see how she performs.
Check the shop actually sells you the BCPR plugs.
Often they'll offer BKR which is the same plug but built to ISO standards and protrudes 2.5mm shorter.
With them you need to give the spring conductor on the coil pack a bit of a tug to ensure it reaches the tip of the plug.
Grab some nickel thread anti-seize and apply a match head dob to the thread of each plug.
Tighten the plugs to the correct torque. Too loose and you'll see carbon up the threads of your old plugs. (the most common cause for stripping plug threads in alloy heads)
Blow the valley area clean with compressed air before you start removing things.
Remove/re-fit spark plugs one at a time.
So easy to drop an item down an open plug hole and suddenly that 5-minute job becomes very expensive.
  • Like 1
Thx Boys. Luckily for me my mechanic friend will be doing the work, but will fill him in with all these tips.
Also picked up a fuel filter, wondering how easy are they to change in the R32 GTR?
  • 3 months later...
I'm reading this topic and it's great but anti-seize
Common! !!!!
You got to think that if you putting that stuff on ya threads you start to isolate the plug from ground !!
Your coil is powering the plug but can't discharge it properly so the it searching for ground ...... Now it will find ground eventually where you did not coat the thread with. Now it can be a possibility of it electrode erode ya head meaning stripping ya threads slowly.
So not a good idea
But if you really find the need to put some lubrication on it... use graphite powder. This stuff is highly conductive and it's a dry lubricant.
Also do not use copper anti-seize coz it's reactive with alloys and normal nickel (silver ) is not good coz it's got lithium grease (non conducting)
Just my 2c
Jiffo I agree with your comment and great tips apart the Anti-seize ;)
    • A realistic expectattion of how long it has to last also comes down to.... when do you think you will be banned from registering and driving old petrol powered shitters? It's 27 years since that thing was built. It probably rusted out 15 years ago. It was probably repaired and looked OK for another 10. If you do a similarish bodge job now, or perhaps slightly better with some actual rust conversion and glassing, then.... get another 10-15 years out of it, after which you'll only be permitted by the CCP to drive electric cars manufactured in their Shenzen zone anyway.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
