Hello
Selling my R33 GT-R, iv had it going on 4 years now, it has developed (Rod Knock), everything else is good, interior and exterior is in great condition
Currently has:
Power FC
BBS LM Rims - Gold
Tein super street suspension
Just Jap cam gears
Electronic boost controller
Splitfire coils
Apexi exhaust system
Brand new tyres that haven't even even seen 1000k's - Yokohama 265 / 35R18 93W AD08-R
Everything else is stock
Also have the stock exhaust system and stock ECU
Asking for 17.5k with NO RWC, and the Rego is paid up until sometime in July, I have to double check.
All inspections welcome except test drives have to be kept to a minimum.
03 9547 - 4292, Vic - Noble Park
or
Email [email protected]
Thanks
Edited by HelloThere
https://www.sau.com.au/forums/topic/452848-r33-gt-r-1996-black-victoria/
And factor in resizing the rods if reusing them, new bearings, crank regrind if its not twisted, and very likely a cracked oil pump if the pistons and bores are still OK.
While there you may as well rebuild the bottom end and clean out everything the oil runs through including the turbo lines.
It may be more logical to simply forge the bottom end or just put a known working engine in.
It will be a engine out and back in job and as XKLABA said, very common on GTR's, dont let it turn you off the car, simply factor in the costs of the repair against whats it worth to you.
This is remarkably similar to the GTR I just bought - 96 black with bbs LMs and bottom end knock lol
Thought you'd stolen it when I opened the ad!
Edit: Never mind :/ Edited by dontyellpl0x
  • 1 month later...
  • 1 month later...
  • 1 month later...
