Hi
My R33 has developed an odd idle issue when you back off acceleration.
The car has an auto box. You can be driving along and take your food off the gas to slow down for a set of lights and the Revs will occasionally drop as low as 500rpm and then bounce back to normal; this does not happen every time though.
I have had two occasions when the engine stopped, however it starts and idles perfectly and drives without issue.
I've cleaned the AFM, new air cleaner, new plugs. Any advices?
Thanks
Denis
https://www.sau.com.au/forums/topic/452860-r33-idle-issues/
Atmo BOV? - Get rid of it
Factory ECU? - After cleaning AAC valve, try resetting the ECU (disconnect battery, operate lights etc, to drain residual power, re-connect battery, start car)
It has been covered qutie a few times before.
https://www.sau.com.au/forums/topic/452860-r33-idle-issues/#findComment-7463815
The engine was fully rebuilt with forged piston, greddy intake manifold, larger injectors, hi flowed turbo, turbosmart blowoff valve, bigger intercooler, Z32 AFM (cleaned regularly) etc etc. The engine has only done 12,000kms in 4 years. There are no mud issues in the AAC or any of the usual issues that are eluded to the great how sections.
Idle is perfect with no fluctuations while sitting. It's only occasionally when you take you foot off the gas to slow for lights etc that the idle drops to 500rpm or lower and then rights itself. This has only occurred in the last few weeks.
I was swaying towards the Turbosmart blowoff valve, but all checked and cleaned and appears OK
Would a TPS cause this? I thought it unlikely.
Sorry if I was somewhat grumpy; you get that way when you're over 60.
https://www.sau.com.au/forums/topic/452860-r33-idle-issues/#findComment-7463852
I dont have any experience with Autos but I had issues when I went from atmo BOV back to stock. Cleaned AAC and all that and it didnt help. Reset the ECU and it returned to idle fine
But im not sure if you are running stock ECU
The TPS on auto has a digital and analog input to the ECU. The on off part is important on Autos if I recall correctly ( the analog voltage signal is important to both auto and manual) the digital input is easy to check with a meter, run a continuity check accross the 2 pin plug with throttle closed and then open the throttle. It should go from closed circuit to open (or vice versa, been a while since I checked)
The other analog sensor is best checked with consult or the correct software for your ECU. Should be 0.45V
https://www.sau.com.au/forums/topic/452860-r33-idle-issues/#findComment-7463875
Hey Dennis, try turning your idle air screw counter clockwise till the engine starts to rev higher. Then turn it clockwise one full turn. Sometimes people fool around with this screw and it can cause major idle issues as you have described. Another possible fix could be to lean off the fuel under 800rpm but this depends on the tune in that area so may not help. I am always concerned about changes to the blow off valve as this usually always causes issues. Make sure it is plumbed back.
https://www.sau.com.au/forums/topic/452860-r33-idle-issues/#findComment-7464343
RB25's tend to want to run a bit rich at idle. I think as rich as 13.2:1 I've seen to give a nice smooth idle.
Off the top of my head I used to run 13.6:1 when I had the Power FC in mine.
Agree about the idle screw, was thinking that the other day. If its wound all the way in the solenoid/valve might be able to compensate just enough to idle, but when its going from higher revs to idle, it can't adjust quick enough or far enough to give a smooth idle.
https://www.sau.com.au/forums/topic/452860-r33-idle-issues/#findComment-7464663
Well after checking all possibilities I turned to the Turbosmart BOV. After winding it back to the softest setting I discovered no more idle issues.
Why?? You tell me.
Easy the stock.ecu likes having the stock bov, a aftermarket bov on softer settings are more like the factory bov
https://www.sau.com.au/forums/topic/452860-r33-idle-issues/#findComment-7467261
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
