Hi Crew
These days are for the complete novice, to the experienced racer.
Details for our next track day.
DATE:
Tuesday 10th FEB 2015
VENUE:
Wakefield Park, 10 km south of Goulburn, is a purpose-built closed road track environment which simulates typical driving corners.
PRICE:
Retail is $295 per person
Forum Special
$250
THERE IS A BOOKING FORM ON www.trackschool.com.au
TRACK:
2.2km racing circuit.
VEHICLE:
Use your own vehicle, or hire one of our race cars from $650 http://www.trackschool.com.au/cars.html
* 1 x Honda Integra Type R
* 2 x Mazda MX5s
* 1 x Nissan 180SX
* 1 x Ford V8 Ute from the V8 Ute Series
PRICE INCLUDES:
* Max 3 groups and only 12 cars in each group
* Plenty of track time
* Well organised
* Pro Instructors
* Free passenger sessions
* $250
GROUP ORGANISATION:
We only allow small groups of vehicles on the track at one time.
Drivers will be divided into groups according to speed and/or experience.
CLOTHING REQUIREMENTS:
Please wear closed in shoes, socks, long pants and long sleeve shirt.
Bring a helmet (helmet hire is available).
Thank you ;)
Edited by Bozman1
Quick question my 32 is unregistered but has half roll cage track only interior ect. would I require a CAMS log book to do these track school days or not? have done 2 SMSP days with SAU with it but thats a club run event. Cheers.
Hi Luke
Sorry for the delay in the respone. It is always best to email ;)
No log book is needed mate. You can bring a stock standard car to any tin top race car or Radical.
All good Bozman i couldnt get time off this time but am looking to bring the 32 out more often so now i know ill try get to the next one.
Thanks again :)
Never driven at wakefield so eager to get out there and have a go.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
