  • 1 month later...
Hi Tom
I have played around with sheet ally and ACL heat shield. It always seems worthwhile but probably not much of a measurable performance gain, more a case of keeping heat away from rubber pipes and there is the benefit of less heat on the intake piping and plenum.
There are some pics in my FS thread if you want to the more overt stuff.
https://www.sau.com.au/forums/topic/452869-heat-shield/#findComment-7493401
Just checked the catalogue.
Payen brand so no idea but heatshielding is pretty worthwhile. Even 6mm sheet ally works very well and that is cheap as chips but might not be as easy to form as some of the dedicated heatshield material.
I have made a small heat shield to fit over the back end of the exhaust manifold, to protect the O2 sensor wiring and the rubber hose plumbing. Used 2mm Al sheet with spacers in between
https://www.sau.com.au/forums/topic/452869-heat-shield/#findComment-7493455
looks very cool! no pun intended. Yes I am looking at trying to block a little heat from spreading to other areas of the engine bay, and as you said the intake and J pipe. After all, nissan had shielding over the whole dump as standard.
Would you mind posting some photos hugh? Interested to see what you have done.
https://www.sau.com.au/forums/topic/452869-heat-shield/#findComment-7493518
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
    • Change the subframe bushes, transforms the car.
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
