Danny's R34 Gtt Build / Diary / Log
  • 2 months later...
since the freddy went on i had to dodgy up some piping so i could drive to the exhaust shop to get my cooler piping made up,
IMG_3509.thumb.JPG.cd14508fdc32a67bf6cc9
I was also in the process of mounting my battery in the boot as i wanted that space free'd up for other things like my BOV, FPR  and oil filter.
IMG_3535.thumb.JPG.2a42b1fe1e330ac52f055
I used the same battery mounts - just modified, a little. its really firm and in a good spot, kinda like the r33.
I also used a 100amp fuse right next to the battery ( in the spot were the cable ties the cable down)
i got 3" piping made up, and right before the plenum i had my adjustable GFB BOV mounted, along with the idle control port.
IMG_3806.thumb.JPG.4e36b697f3279bda96593
IMG_3836.thumb.JPG.f16891e884200372b92b3
the BOV can still recirculate wasted air as the exhaust shop has made up a small 1" pipe that carry's the air from BOV back across the radiator and plumbed back into turbo.
when I was able to drive the car again i noticed my acceleration pedal was rather "sticky" that was due to a crappy throttle body, i tried modifying it and tried to make it better but it was hard to crack open and it liked to stay open after you take your foot of the pedal.
IMG_3868.thumb.JPG.8a60c545f0cf0e02c4caa
anyway my tune was booked in so i took her in and it was tuned with a dodgy throttle body on, shortly after replaced with a HyperTune Q45 throttle, and it was fantastic!
made just under 350kw's
IMG_3866.thumb.JPG.73b2cd55c353ec61ba7b9
IMG_3875.thumb.JPG.aae29f10364daeec179d2
IMG_3876.thumb.JPG.f7b8c13783d2128f4cd7d
I did still however have a high idle (1100rpm) with my idle adjustment screw wound in i found the only way to bring the idle down was to disconnect the electric adjusting motor, which i later put in a switch so i could keep the higher idle for cold starts.
Next up was re-going over my braking system.
I was using EBC blue stuff pads which didn't do too bad for the price, but i need something more reliable and something with more bite, so i switched over to Project U's HC 800 pads, coupled with some DBA track rotors, and HEL braided lines.
IMG_3902.thumb.JPG.faa0a7f782186edf17f0aIMG_3916.thumb.JPG.d2500fb46ec1dc3cfc1b5IMG_3918.thumb.JPG.6d424deddadf7577e7520
I got the pads and rotors in, but haven't yet done the brake lines
when changing over pads i for some stupid reason decide to throw out my anti squeal shims *angry face* so when i put this pads in they squeal like crazy!
so I did purchase some new anti squeal shims, along with seal kits for all 4 callipers, which i plan to instal soon.
This low KM 250GT popped up for sale real cheap, so it became the missus new daily!
IMG_4130.thumb.JPG.6cf6802c8561208f4925bIMG_4132.thumb.JPG.a68008595b60ea47483f0IMG_4134.thumb.JPG.6a813cebaba7e38bc786f
I had been having drama's with the car -
it occasionally after a bit of a drive refused to start when warm... 5 mins later it would start.
as it got worst it started miss firing at around 3k rpm, eventually it refused to rev past 3krpm and just had ignition cut!
It turned out to be a faulty CAS!
the disk inside the CAS had scratches and wear marks on it, so replaced with another one and it came back alive :)
andddd because today was such a nice day i got some painting done :)
so happy with my devilbiss SGK 600! I fan it out a bit more when laying down colour, and then concentrate a tiny bit more for clear, and it comes out great!
it was still a little cold when i did my bonnet but nothing a block back and buff won't fix :)
Whilst at the tuners - he noticed a slight exhaust leak, also was told my intercooler isn't flowing to well..and then later to have a problematic CAS makes me think that I should go back for a re tune with a better cooler, probably plazmaman.
Went for a bit of a boost today while giving my new camera a run, and the Z-tune bonnet i had repaired ripped apart from the skin :laugh::banana:
that was fun.
heres a video of it happening -
and some photos when i got it home.
that was fun.
Whoa that's pretty extreme! You're lucky, doesn't look like any damage to the window or the roof – and no accidents!
I'm not too sold on aftermarket bonnets now having seen this...
  • 3 weeks later...
Nice build mate
Very similiar to mine.
Neo with an ATR45 turbo. Though i think yours is a newer design got mine a few years ago.
Differences:
Mines a build motor, brae side mount manifold, internal gate, stock airbox, return flow cooler
Can't find my dyno graph but this will do for now
14291709_1410986545582367_19880591555517
Edited by blah_blah
  • Like 1
  • 4 months later...
Haven't done much recently, but still playing around with the body kit, I've sprayed up my side skirts, rear bar and fitted them.
I'm pretty happy with it.
I'm still looking into a new diff, then perhaps later down the track a plazmaman cooler new coil packs and a re tune.
added some photos i took with my mates too. :15_yum:
I'm gonna say for the first time I am considering building the motor... No fancy 25/30 stuff either just straight up 25neo built.... maybe one day if the wallet allows. stay tuned.
  • 1 month later...
Update - bought a second hand bonnet, cut the lip off, and it fits perfectly with the front bar.
then cut out the Z tune fenders and threw it on!
looks like i could make this work....
now for some more cutting and bogging.
I've been adding regular videos to youtube just based around my 34, heres something i threw together after a day down the Great Ocean Road-
  • 1 month later...
Got my lazy ass of the couch this weekend, made that bonnet fit - painted it gloss black, looks really good.
had to raise the front coil-overs a little just so i could get out of my driveway.
and was noticing it was becoming increasingly more and more difficult to start - I put this down to the E85 and cold weather but turns out the little battery just wasn't keeping up, turns out if these cars don't see a good amount of voltage they won't fire.
I had already moved the battery to the boot so had plenty of room, I just upgraded to the biggest battery i could fit/afford, then used "0" gauge cable on it.
going to upgrade the starter and alternator wires to "O" gauge in the future.
Pics -
Battery before and after (exciting stuff)
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
    • does anyone know the specs of the R35 master cylinder, rear ratio and knee point? the BM57 is a 0.4 rear ratio with a 435psi knee. I'm looking for someone with a much lower knee pressure. the piston area of the R35 brakes isnt that big so might not work for me but this is interesting.. the other option for me is a GU patrol master cylinder and booster and do the prop valve externally.
    • It sounds like by avoiding maintenance you may be doing more damage than a hypothetical guy in a workshop taking it for a spin. Not sure if you are just being paranoid or things are actually that bad in the US. Find a reputable shop not run by dickheads. Look for people that take pride in their work. Stick around for the day if you have to
