Hey guys, sorry if i'm posting in the wrong section of this forum as I am new to it, i got my 1993 R32 gts-t 60th anniversary about a month and abit ago and i think it's time to get modding.
the car is completely stock (rb20) besides a k&n filter and thats it. Ive heard rb20s aren't really good for going over 300hp ish or something like that. I don't really have a budget but I don't really want to be spending much more than a couple of grand if that. I really want to get to as close to 300hp as I can, and not run too much boost as it will probably f*k it up abit, i think 10psi would be the highest id go by what ive driving, knowledge and stuff...
i was pretty much just thinking along the lines of a exhaust sys, tune, little bit higher boost and stuff like that! im very new to this! it is my first car and I want to start fiddling around with it :)
cheers guys, please let me know if i'm posting in the wrong section, sorry in advance if I have!
jack.
https://www.sau.com.au/forums/topic/452892-r32-gts-t-easiest-mods-for-power/
couple of things I forgot to mention, my tires are really wide and fat, definitely more than illegal! way past the fenders but Im not gonna buy wide fenders for it just gonna try my luck and not get caught haha, and another thing I really do not want to do is change my turbo, want to keep that stock :)
Well you car is not "completely stock besides K&N filter" then is it? As above mate, everything you want to know about your car is in these forums, happy hunting! Use google to search this site, e.g. "site:sau.com.au rb20 dyno thread".
yeah I know it isn't i forgot to add that stuff in haha, for the time be-ing, i was just thinking exhaust system and a tune..
do you/anyone have any suggestions of a good exhaust? a link to the product would be much appreciated aswell! thanks
jack
I have an rb25 Neo.
I started with
Exhaust
Pod (later changed to hi flow panel filter)
Blitz dual sbc Boost controller (10 psi)
Front mount intercooler
Then:
Nismo fuel pump
Better suspension
Split fire coil packs
Bigger wheels and tyres
Gktech fan
Nissan Water pump
Nissan Timing belt Bearings seals
Hpi evolve radiator 50+mm
Nissan thermostat
In feb:
Id1000 injectors
Nistune
Z32afm
Atr43ss2 turbo
3"metal intake
And I logged religious 5000km services in between.
It took me more than two years lol but I was just worried my motor would fail on me if I just slapped on some mods.
You get the idea though.
nice guys! thanks for the replies! rekin your r32 looks so clean :D
Therealsandybang yeah i get where you're coming from, space the mods out over a period of time instead of slapping them
all on there at once, was the fmic worth it aswell? because that was something else I was considering
In saying that, are fmic's worth it? if I was to get one I could not stand it hanging out like a vl turbo i'd have to
have it tucked away hidding and (black) for the stealth look :) if I could do that easily somehow or get proffesionals to do it
any fmic suggestions for a r32 gtst guys? thanks much appreciated for the feedback!!
Jack
I started off with a cheap Kkr black series intercooler: $400
I've since popped on a blitz return flow $500-600
Do you have a side mount cooler?
It will be nice and responsive and good near early 200rwkw.
But may heat soak in longer spirited runs
The extra piping in a return flow or bigger front mount if you had a side mount may marginally increase lag.
(Correct me if I am wrong?)
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
