haha i had another guy ring me after seeing it out front yesterday aswell :P
doing more summer prep, tint has been booked in. dash mat in place thank to you adz
also replaced the metal nismo gearknob with the leather version thanks to wantGTR.
  • Like 1
Well would you look at that. Glad its gone to a good home.
Are you still chasing a hard pipe kit? My mate has one for sale. A full greddy one off a bnr32
yeah i probably should get that sorted soon, got a link or anything?
I have narrowed an issue with an rpm hesitation i have been having down to the TPS so im getting that sorted tomorrow and i will also finally have a GTR back seat to go in (embarrassingly been using a gtst back seat up until now)
I'm gonna go on the SA GTR cruise this weekend to give it a proper drive, if the tps sorts the problem out i will get back to modifications.
turns out the other TPS we had was the wrong one, so to see if we could fix the issue we took the old one out and cleaned it up. testing it it does have a dead spot which we managed to get rid of, we tested all other sensors which were all good. put it back on.
now it has made it better but its still not right so we have ordered a new one anyway, its obviously just not right and there cheap so yeah.
interestingly it has created another issue, if i rev reasonably hard, say over 4000rpm and let the revs drop out of gear, it drops right down to stall, hoping this is just due to the dud tps, but we shall see when the new one arrives.
i did managed to take it for a good drive with some other SA GTRs which was good. car performed really well, the dead spot is between 2500-2800, somewhere in there so hard drivings not an issue.
also pulled my finger out and washed the GTR back seat i got from Josh and got that in. f**k i hated the gtst seats someone put in it.
yay
i know i probably shouldn't be that exited about a back seat but i am.
  • Like 3
  • 4 weeks later...
ok been a while since i updated anything. spent a week in bali for my 30th which meant the car was off the road for more than 1 day which never happens, so i took the opportunity to finally get the subframe pulled out and replaced the much needed bushes thank again to josh at Forge.
the original bushes are knackered and the subframe movement was getting to a serious point.
received_1274430752582898_zpsoryu5yoi.jpreceived_1274436109249029_zpsgo3f34k1.jp
check out how much movement there is. imagine this transferring through the diff on accell - decel.
http://vid30.photobucket.com/albums/c330/whitesi/GTR/received_1274573842568589_zpsqh1ia8y7.mp4
so, new bushes arrived and the subframe came out. new bushes, new fluids and a happy rear end.
received_1274436052582368_zpskpl2nqz6.jp
rear end is obviously much tighter and much nicer to drive.
also had the intake modified to remove the turbo shuffle thank god.
Edited by GH05T
  • Like 1
also, i have been ...slowly... being lzy... but chasing down the slight hesitation issue and i have been blaming the TPS... which i still do. but i have also just discovered that my BOVs are venting to atmo.... so yeah... might need to just fix that up :P
  • 4 weeks later...
Haha, just at work. Shitty plastic on a cheap head deck. So i have bought the same head ubit i loved in my stag which was a really good media player that you could plug a massive hdd into and it also had a wicked clock :P
Also got a full set of alpine r type speakers, 3 ways for the rear and splits for the front aswell as a small 10" sub in a sealed box (for hard kick over droning bass) and amps to run the lot. Should be a bit nicer than..... well... nothing.
    • But if you've got the flex sensor whats the issue? You just run what you can get your hands on.  I can't see any reason not to run e85 if it's relatively local to where you live.
    • Exhaust end of this month, and then tune after that whenever there is availability. Still tossing up between a pure 98 tune or a flex 98/e85 combo.  The (lack of) milage in e85 isnt great. Start to get anxiety if i go for a long drive and there arent any united servo's nearby
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
