sweet, by square i mean the same front to back but yeah im not looking for stanced out stretch or muffin top either :P i actually dont mind a slightly stretched tire on looks but its simply not needed for the offset of +20 so it wont be done.
imo.. well in my mind, 265 fronts would tram-track a bit, probably not an issue really.
its a shame they dont make +12 or similar in the xxr wheels, wouldn't mind pushing them out to the guard edge a but further but hey, beggers cant be choosers, their a cheap wheel which actually look half decent.
my current wheels are 17x9+22 and sit like this ...
the new specs at 265 are perfect (chears ;) ) to keep the tire size spot on.
would consider running spacers for looks but not for a daily, not JUST for looks, well not on a daily basis anyway.
Edited by GH05T
Are your gaurds still stock? If so i would leave them. Forget the stance fad or whatever. Gtr gaurds are big enough to throw a decent tyre under there.
Im sure you would have trouble breaking traction on good tyres and a proper wheel alignment. Fuse in of course!
loved the detail/work that went into your old 31 on the 31forums etc...
the 32gtr looks clean, loving it currently, bride looks at home in the interior,,, selling the gtr seats? #cawwwwwcawwwww #thatsstevenseagulltoyou haahhahahahaha.
In the way of the wheels as much as flush/mexistance/ultrataco looks cool etc, personally i think wheels/fitment as above is good size, without being too "stanced" its rad but funtional... age old saying, if it aint f**ked, dont fix it.​
​definitely going to keep an eye on the future progress regardless.
unless you ruin it then ill bomb you isis styles. boom here comes dat boom here comes dat yall don't really want it now... :P
fkin lol.
bride seat i moved on for tip top condition gtr seats, still havnt done the back seat but im not fussed cos it seems to carry allot of car parts, wheels and shit and i dont care if it gets marked up.
fitting up now.
very happy with how they fit with the guards.
as its a daily, i have gone for the cheaper goodrides as suggested.
good looking tire, will see how they fair.
will get good photos soon ;)
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
