its close. and its touched a bit which is evident from some tarnished. i want to get a nice TI exhaust at some point. then ill work the hangers out.
a dude came up to me at the end meet who owns a nice 33gtr with some porn... i think work wheels. added me into the gtr cruising club. let me know if your a member. he was parked upstairs too. keen to get out with some more gtr guys
Yeah TI exhaust would be awesome but for me it's for minimal gain haha.
Have a 3in AM performance dump back from ages ago and it works well (and sticks out a abit)
nope not in that group.
Yeah was alright.
CF overlay in visible areas, rest i think was FRP.
Fitment is perfect and quality is good.
I mean, even if it was the original abflug lip, it would essentially look the same.
excellent will buy a few things from the current one going then.
was a bit hesitant due to fitment as its hard to umm shape and what not carbon overlay with out damaging it etc
as my boot already has holes in it from the original spoiler, im going to assume i can just drill into the base of the spoiler (carbon copy styles)
what screws/bolts whatever, would i use to hold it? just something relatively large and self tapping or?
Yeah, its a permenant fixture option lol. Yes it will damage the paint so would advise against it unless its never going to be removed. I used 3m tape on mine. 240kph and it stayed on. Dont remember which particular tape it was though, they arent all the same.
  • Like 1
yes well when i fit the spoiler it is unlikely i will be taking it off. when i do it will be for a respray anyway, the boot needs it due to some irreparable scratches.
i had a test fit yesterday with some double-sided thick tape but it was a bit shit. the fitment is not %100 either so it needs to be pressed down.
im thinking of just using the tape for placement and to seal it and using proper screws to fit, like i said i already have the boot holes so might as well make use of them.
picked up a larger front pipe and fitted it up in the hopes that i would get a bit more volume from the exhaust.
even though the pipe diameters are larger it made f**k all difference.
i know i need to probably do the dumps but ill do that when i do the turbos as its a bitch of a job.
i might even look at deleting the center muffler, the rest is quite large Apexi fitup and a decat.
Edited by GH05T
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
