Looks quite nice, im starting to get old enough I appreciate the retro style of keeping someone original even if it does look as good.
I was trawling the cars for sale and I notice you posted on quite a few r32 gtr for sale threads before you got this one. Congrats on finally having her in the garage
haha, yeah i bugged allot of people.
im amazed i actually ended up buying in adelaide tbh.
now im pestering all the for sale threads :P
Edited by GH05T
  • Like 1
i have a 32GTR also that i am restoring
Regarding your HICAS issue - sounds very similar to the issue i had. Do you have an aftermarket steering wheel by any chance? If so you may have the wrong boss kit which is incompatible with the hicas clock behind your steering wheel
In my case fitting the correct boss kit and aligning the steering wheel and hicas clock correctly fixed my issue. My HICAS light would come on exactly after 10kms of driving on the freeway
Jase
Thanks jase. Tested this today. Reset the counter and yup, bang on 10km the light pips on. New wheel should fix.
hit the paint on the bonnet today,
the bonnet particularly had been buffed or something before and had allot of swirling.
the paint was smooth after a good clean and the claybar but harsh big swirls.
this is a photo after the claybar where in this light you can really see how bad the bonnet was.
25ab3a05-2a2e-48d5-9661-c840017bcd62_zps
i did try quickly with the electric buffer but the pads old and i didnt want to balls it up so i went back to hand for this one.
not sure how well you can see it but what a difference after just a quick cut.
cut on the left vs uncut on the right.
finished it off with some good wax. soooooo smooooooooth but also nice and deep., cant wait to get some more gear for the rotary buffer and go over more of the car but happy the bonnet is now done. luckily this was the only panel which had this much swirling.
Edited by GH05T
  • Like 1
it seems i still have a coolant issue to chase,
seems to be either the same small line at the back of the engine has let a clamp go, or something similar.
cant quite see with the car on the ground but its right up on the head.
always the way with pressurized cooling systems, fix one week link and wait for the next to go.
decent amount of coolant coming out too.
possible suspect.
  • Like 1
As suspected the coolant leak was the next link in the system, damn heater hoses at the back.
One has gone, the other looks aged. the third looks ok but im not pulling the manifold of to do only 2.
annoying thing is two are out of melb stock but the third is out of japan apparently...
good news is, seeing as we are taking the manifold off anyway it gives me a good excuse to have the throttle body linkages all adjusted and set correctly to bring my idle down from the slightly annoying 1200rpm which has been bugging me.
cars off the road until these damn hoses come in.
Grats on the purchase and I'm sure you'll get great enjoyment for years to come.
I've had mine for about 5-6years now and had been in storage for the last year, getting some work done and back will be back in my hands shortly.
I recently put on a set of RPF1's 18x9.5 +15 in matte black (car is BNR32/KLO) and they look great. If you need any pics for fitment/etc feel free to PM me as I pestered alot of guys on here before I put down the money.
Mine will be a daily soon
  • Like 1
Always a good idea to have some pressure testing equipment in the garage and give the cooling system the odd test. Doesnt hurt to get it up to temp either and give the top radiator hose a sqeeze and see if the radiator cap is still working and holding pressure.
basically the same as what i will get except silver.
there seems to be a few places doing cheap deals on them brand new too.
You could go wider depending on what you wanted but that'll need work and won't be stock styles as you've mentionned earlier in the thread.
I think 9.5+15 are a pretty good fit. Pulled out my guard liners for now, might put the rear half on later...
Think it was around $1.6k iirc or something like that, could be cheaper now etc
heater hoses done, they managed to get to them faster by removing the brake master,
haven't tackled the throttle linkages as we didn't remove the intake plenum but were gonna do that at the same time as we do the timing belt and squeaky tensioner.
will probably dyno and up the boost at this point.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
