Searched half a day but no luck finding the info.
New setup:
R33 Track Only
RB25/30
E85
Fuel cell -> Filter -> Bosch 044 -> Surge Tank -> 2 x Bosch 044 -> check valve -> Y merger -> Filter -> Stock fuel line -> Stock side feed fuel rail, 1200cc injectors, stock FPR
My questions are whether the items highlighted in red is capable to run 400rwkw on E85?
Thanks in advance lads.
Edited by kliono
1200cc side feeds? Damn they are using big drill bits these days...
Yes, they should flow enough, although the fpr may not bypass enough with twin 044's (causing high base fuel pressure.) I guess you don't care about what happens at idle and cruise though as it's track only.
  • Like 1
Yeah hahaha I just read heaps on the JECS injectors review. A lot of people had issues running unleaded (idling etc) above 750cc, shit latency and poor spray pattern. Aside from those few people had issues brand spanking new injectors stuck running e85 so different fuel different problems. I'm going to flush them after track anyway by running it with unleaded so no big dramas.
With the flow, I can weld fittings on both end of the stock side feed fuel rail and cap off the original entry and exit, run sard fpr if that helps?
Circuit Sports do a side feed rail which I believe is dual entry, but could be wrong
I agree that you may as well go top feed modern injectors, but if you are hell bent on sticking with side feed then I would suggest the circuit sports rail
You'll be fine. It will flow the fuel no issues. Those 1200cc injectors are a bit iffy though.
Many people have had them die and I met someone who destroyed an engine because it failed under load
Not at all man. Sometimes if the stock components are up to the task then there is no point spending the money, same logic as forging a 300hp RB with no plans of bigger power. Decided last night, going to go with:
ID2000 injectors
Proflow top feed fuel rail kit RB25 plenum
Sard FPR
The JECS 1200cc is now stupidly expensive to what it is worth at $800AUD + shipping thanks to the conversion rate.
I was making 490rwkws E85 on stock fuel rail and lines. They are fine.
Hypergear, sorry, to elaborate some more for people that may google this question in the future. These are on;
1. Stock lines
2. Stock RB25 side feed fuel rail (non modified entry/exit)
3. Stock fuel pressure regulator
4. Injector size?
490rwkw nice!
For the questions:
1. Stock lines
Yes
Yes
Sard fuel reg.
4. Injector size?
Ebay Junk 5x0 1200cc injectors.
they work, but they are shit
they idle, but idle rich
they are gay, yes..
here's an entire thread I started on nissansilvia.com about them:
http://www.nissansilvia.com/forums/index.php?showtopic=2441472
enjoy the read... then once you're done, convert to top feed:
http://www.trak-life.com/diy-converting-top-feed-injectors-r33-gts-t-skyline-rb25det/
and here's your chance to score a top feed conversion kit at a good price
http://www.sau.com.au/forums/topic/452356-bilstein-shocks-apexi-power-fc-for-ecr33-rb25-top-feed-fuel-rail-splitfire-coilpacks-syd/?p=7468587
just need to get the injectors and harness separately and you're set
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
    • I'd be looking at the mentioned EFR kit, room to turn it up if decide on e85 (which we know you will) and be super responsive and fun on the street. OR https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/?srsltid=AfmBOorrJa2S76JR5ekXprxBOtU44a1UProbe64YaiVi9zTVp1Lj814w And add whooshy noise for extra fun C5 corvette prices are coming down locally here and a mate has a manual one and is a heap of fun on the street and track.
