I was...now i am only a small chance. Combination if nobody else interested as was only going to be and one mate plus a 3rd who would be working. Also the hiccup is i am going to Monoco so trying to save some cash and hoping to do Le Mans next year. Will see how the year pans out but may do Fuji
  • 1 month later...
I am just a prick. I dont like how the Sky F1 commentators are so one eyed and Ant always calls rubbish to support any English driver. I wouldnt have been able to watch any of the remainder F1 coverage as I would have had to listen to LeMans winner Ant yadda yadda.
There was a funny moment mid-late Le Mans when a commentator rightly gave Ant a compliment and then the other English commentator starting BSing on about how clearly he was the fastest driver in the car. The other commentator pulled the guy up and stated "that they all equally do a great job, one is no faster, better than the other" . But minutes later he again said Ant was clearly the fastest Toyota driver only for the other commentator to pull him up and say on speed along Kobi had proven to be the quickest over the week. Its just an English commentator thing as a rule. Buemi is a gun and he never gets a mention by them.
I am just over the English love in, just as much as I am over "Australia's Mark Webber"..."Oz's Danny Ric" etc etc. LOL, I am a miserable bastard at the moment
wow - many feels for you too Roy.
They are just commentators mate don't take it too hard
Then again everyone has their 'off days' some longer than others, but then again the English have always been smug when it comes to sport.
I'm struggling to work out why any Nissan heads would feel sorry for Toyota.
Nissan absolutely dominated as an Engine supplier,,, suck on that Toyota,,,.
Still to this day the Rotor company is the only Jap Company to win outright.
I'm not into Karma but it bit them sweetly on the arse when their arrogant shithead last driver flashed the Audi car an hour and a half out. He wasn't warning them he was coming, he was saying "sucked in we are going to win and you are shit" Even the bias pommy comentators said as much.
Cheers
Neil.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
