Captain Wow Posted January 20, 2015 Share Posted January 20, 2015 Hey all, The Mrs has decided to come over to the dark side and nab herself a M35 Stagea as her next car. I was wanting the opinions of people in the know, more than I, what the best model of the M35 is. On a quick search I see there is around 6 or so sub-variants of the car, and as I've never owned a M35, I'd not have a clue which one was better than the other. The car will ultimately be a kiddy wagon, however, that by no means, means it has to be boring Anyways, let the opinions begin! Cheers, - Lance Link to comment https://www.sau.com.au/forums/topic/452941-picking-the-right-m35/ Share on other sites More sharing options...
KiwiRS4T Posted January 20, 2015 Share Posted January 20, 2015 Depends how much you want to spend. New regulations make it difficult to comply 250s so all newer ones tend to be 350s which have the same power as the 250 turbos. For example TradeMe auction 83300352 a 350 with 67K for $11k 250s are to be had from $5k but it may pay to look for one that has had the $2k cam chain replacement job done! Link to comment https://www.sau.com.au/forums/topic/452941-picking-the-right-m35/#findComment-7464741 Share on other sites More sharing options...
Brick Posted January 20, 2015 Share Posted January 20, 2015 The pm35 (series 2) is probably the better every day car. The nm35 2.5t model is the better performance option. Other then that it is more a staying difference between those sub models then an actual model difference. Even some low grade cars with stock outside can have everything the higher models had if the owner ticked the boxes Link to comment https://www.sau.com.au/forums/topic/452941-picking-the-right-m35/#findComment-7464746 Share on other sites More sharing options...
Captain Wow Posted January 21, 2015 Author Share Posted January 21, 2015 Cool, thanks for the input so far guys. To a point, money isn't a problem so I'm not too worried there. Okay, well if the 3.5's have the same power output then I'll probably go off the hunt for a 25T as it'll have more potential for issues which is not what I want for this car. Besides, that's what the C34 is for lol. - Lance Link to comment https://www.sau.com.au/forums/topic/452941-picking-the-right-m35/#findComment-7464842 Share on other sites More sharing options...
66yostagea Posted January 21, 2015 Share Posted January 21, 2015 Depends how much you want to spend. New regulations make it difficult to comply 250s so all newer ones tend to be 350s which have the same power as the 250 turbos. For example TradeMe auction 83300352 a 350 with 67K for $11k 250s are to be had from $5k but it may pay to look for one that has had the $2k cam chain replacement job done! Interesting about the cam chain replacement. When does it need doing? I ask this because my original RMR30 did 600ks and was never replaced. Link to comment https://www.sau.com.au/forums/topic/452941-picking-the-right-m35/#findComment-7464901 Share on other sites More sharing options...
MrStabby Posted January 21, 2015 Share Posted January 21, 2015 IIRC the 3.5s have more bottom end and more top end, and the 2.5 turbos have more midrange. Might be worth driving both to see which you prefer. Link to comment https://www.sau.com.au/forums/topic/452941-picking-the-right-m35/#findComment-7465143 Share on other sites More sharing options...
Hertz Donut Posted January 21, 2015 Share Posted January 21, 2015 If I was buying again I'd go for a PM35 (RWD) due to the greater crossover of parts with G35s and 350Zs. Having said that the only thing that even slightly worries me about my PNM35 is around-town fuel consumption, and now prices are down even that's not such a hassle. They're fantastic family wagons and I have yet to run out of space when taking the family away, I normally find myself looking for more things to put in the boot to stop everything bouncing around. Link to comment https://www.sau.com.au/forums/topic/452941-picking-the-right-m35/#findComment-7465341 Share on other sites More sharing options...
scotty nm35 Posted January 22, 2015 Share Posted January 22, 2015 Interesting about the cam chain replacement. When does it need doing? I ask this because my original RMR30 did 600ks and was never replaced. It doesn't, unless it has never been serviced, or the K's are stupidly wound back. Link to comment https://www.sau.com.au/forums/topic/452941-picking-the-right-m35/#findComment-7465510 Share on other sites More sharing options...
iamhe77 Posted January 22, 2015 Share Posted January 22, 2015 Have owned both a 250t RS Four and (currently) a 350RX Four. Go the 3.5. Interior (everything) is much nicer. Exterior is nicer. Transmission is nicer. AWD system is easier (no need to worry about external pumps). Engine is common although the 2.5t is much better for cheap performance. 3.5 is a better drive in factory spec. if you are modding, anything up to 6-7k will see significant performance increases with the 2.5t and okay increases with the 3.5. If you are spending big for performance ($15k+), you will get more out the 3.5 but it will require stronger internals. Neither have to be "boring" (brakes, suspension and bracing perk up the drive quite a bit) and both make an excellent kiddy wagon. Link to comment https://www.sau.com.au/forums/topic/452941-picking-the-right-m35/#findComment-7465541 Share on other sites More sharing options...
nickcorr Posted January 22, 2015 Share Posted January 22, 2015 Hey Cam, must be nearly time to try a J50....... Link to comment https://www.sau.com.au/forums/topic/452941-picking-the-right-m35/#findComment-7465789 Share on other sites More sharing options...
iamhe77 Posted January 23, 2015 Share Posted January 23, 2015 (edited) Looked. Do like, but not enough room in the back for the dogs Edited January 23, 2015 by iamhe77 Link to comment https://www.sau.com.au/forums/topic/452941-picking-the-right-m35/#findComment-7466285 Share on other sites More sharing options...
Captain Wow Posted January 27, 2015 Author Share Posted January 27, 2015 Cheers for all the input lads, I'll be looking seriously into the 350RX Four by the sounds of it. Going to be weird having two Stagea's in the garage lol. - Lance Link to comment https://www.sau.com.au/forums/topic/452941-picking-the-right-m35/#findComment-7468609 Share on other sites More sharing options...
