Hi All,
Can someone help me out with this,
Need some tips on the settings I should run on my r34 gtt for a wheel alignment, looking at setting the car up for drift.
As for suspension gear it is fairly stock aside from bc coilovers, adjustable castor rods, adjustable front and rear sway bars and tie rod ends. All the camber arms and bushes etc are stock aside from this.
Can anyone shed some advice on the set ups they have tried and tested?
Any help appreciated.
https://www.sau.com.au/forums/topic/452956-wheel-alignment-settings-for-drift/
My 2c.
Run some toe out on the front to help the car turn in. Too much toe out on the front will make the car twitchy in a straight line however.
Start off with zero toe on the rear and add some toe in once you get comfortable.
Start with 7-8 degrees of positive castor. Circuit drivers will tell you to wind in as much as possible, but too much positive castor induces positive camber on the inside wheel at opposite lock.
Keep the ride height at a suitable level so the standard geometry can do its thing. Too low and you start messing the roll center, bump steer etc.
Start with the rear swaybar on hard and the front in soft and go from there.
I like to run the dampening on the softer side on the front and stiffer on the rear. Others will tell you otherwise. Start midway and see how the car feels.
So something like this.
Front toe: -6mm total (-3mm each side).
Castor: 7-8 degrees positive.
Rear toe: Zero.
Good luck.
Thank you for the advice really appreciate that, will try those settings.
I am raising the ride height as it is a bit too low especially in the front, want it to be able to turn without scrubbing. Interesting to run the front dampening softer than the rear have always heard people say front needs to be harder then rear, will try it though can always adjust on the day.
Yeah the dampening settings are more a personal preference, I like how the car feels and responds that way. You may find that it doesn't work for you, but every setup is different. As you said, adjusting the dampening is probably one of the easiest ways to change the balance and feel of the car, it's all about finding what works for you and your cars setup.
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
