Hi All,
Can someone help me out with this,
Need some tips on the settings I should run on my r34 gtt for a wheel alignment, looking at setting the car up for drift.
As for suspension gear it is fairly stock aside from bc coilovers, adjustable castor rods, adjustable front and rear sway bars and tie rod ends. All the camber arms and bushes etc are stock aside from this.
Can anyone shed some advice on the set ups they have tried and tested?
Any help appreciated.
https://www.sau.com.au/forums/topic/452956-wheel-alignment-settings-for-drift/
My 2c.
Run some toe out on the front to help the car turn in. Too much toe out on the front will make the car twitchy in a straight line however.
Start off with zero toe on the rear and add some toe in once you get comfortable.
Start with 7-8 degrees of positive castor. Circuit drivers will tell you to wind in as much as possible, but too much positive castor induces positive camber on the inside wheel at opposite lock.
Keep the ride height at a suitable level so the standard geometry can do its thing. Too low and you start messing the roll center, bump steer etc.
Start with the rear swaybar on hard and the front in soft and go from there.
I like to run the dampening on the softer side on the front and stiffer on the rear. Others will tell you otherwise. Start midway and see how the car feels.
So something like this.
Front toe: -6mm total (-3mm each side).
Castor: 7-8 degrees positive.
Rear toe: Zero.
Good luck.
Thank you for the advice really appreciate that, will try those settings.
I am raising the ride height as it is a bit too low especially in the front, want it to be able to turn without scrubbing. Interesting to run the front dampening softer than the rear have always heard people say front needs to be harder then rear, will try it though can always adjust on the day.
Yeah the dampening settings are more a personal preference, I like how the car feels and responds that way. You may find that it doesn't work for you, but every setup is different. As you said, adjusting the dampening is probably one of the easiest ways to change the balance and feel of the car, it's all about finding what works for you and your cars setup.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
