  • Replies 345
Hello fellow Canberrans :-)
Hey Shell.
Long time no see !
I'm still pee'd off that I couldn't make the last cruze !$#@
Well, for the next one you'll get to see/hear my new 3" exhaust and wheels :-)
I'll have to take a new pic for my avatar...
Have you got your pod filter on yet ?
If not, hassle Jay to give you a hand (which probably means coming to my house so I can do it for him, LOL only kidding Jay :-)
https://www.sau.com.au/forums/topic/453-act-roll-call/page/2/#findComment-12329
KamikazeR33...I think you should be in our group :P
and we'd love to have you!!
Round up that group of 32's & 33's and come on a cruise to Canberra sometime!
NSW/ACT is going to be a joint section of the club anyway. Unless we get more members from the ACT, but for now, we're with the NSW guys.
https://www.sau.com.au/forums/topic/453-act-roll-call/page/2/#findComment-15052
Originally posted by Shell
Jeez you're a nosy thing aren't ya George?? :cheers::P:p:p
(just kiddin babes!)
i thought you might have been lonely so i came over for a chat.
hey, you hear birty is coming down in August. you should come up then. i can't keep him entertained all by myself. he's a handfull i hear.
https://www.sau.com.au/forums/topic/453-act-roll-call/page/2/#findComment-16399
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
