  • Replies 345
Originally posted by Birty
At least he doesn't sit in his little NSW forum and post once every 3 days....:shake: :shake: :shake:  :burnout:
wtf are you on about Birty?? :confused:
George...absolutely positively...I will be putting up some info on that Sydney/Canberra cruise soon. I have a plan worked out...just have to get some final details...we can push the dates forward to when Troy & Kyles are here :cheers:
https://www.sau.com.au/forums/topic/453-act-roll-call/page/3/#findComment-16917
Guest 200zt
Hi there,
I know it isn't really the same, but I have a Datsun 260z with R32 RB20DET in it.
It is good to see a few Skylines getting around Canberra....
For those interested, I have included a picture - note I am obviously pretty bad with a camera, because the car is red, not pink, like the picture suggests! :P
https://www.sau.com.au/forums/topic/453-act-roll-call/page/3/#findComment-21999
G'Day, my names Andrew and i live in kambah and drive an R32 GTS (turbo coming!:P ) unfortunatly the car is bog stock except for a minor stereo and alarm, with BIG plans on their way!
i wouldnt mind cruising with u guys in canberra sometime
https://www.sau.com.au/forums/topic/453-act-roll-call/page/3/#findComment-28886
Supafly as in Supafly car club???????
https://www.sau.com.au/forums/topic/453-act-roll-call/page/3/#findComment-28932
Originally posted by Shell
.... (look out for a wine red R33 :mad: )....
Pffffttt......what a crappy colour.....:D:( (joking Shell, joking...)
Ok, I'll go back to my hidy hole, now. But I'll be back when I eventually get my GTR.
Mwwwaahhhahahah......ahahahha.....ahahah *fading evil laugh*
https://www.sau.com.au/forums/topic/453-act-roll-call/page/3/#findComment-29630
a GTR, Tim? tell me more :D
and u know how cool red is, no need to pretend, we're all friends here :mad:
SupaFly...mine is very much a daily driver...hehe I can prove it - it's always dirty LOL! I live down near Athlon Drive (near the lake). Whereabouts are you? I've never seen an R32 around Kambah :(
https://www.sau.com.au/forums/topic/453-act-roll-call/page/3/#findComment-29724
a GTR, Tim? tell me more :)
and u know how cool red is, no need to pretend, we're all friends here :D
My 5 year plan - buy a house and a GTR. :)
LOL.........Silver is a cool colour Shell, Red is only cool when it's on a car with a prancing horse emblem!!! You know it's true...:uh-huh: ;):D
Drift Spice.....LOL......has class.:)
https://www.sau.com.au/forums/topic/453-act-roll-call/page/3/#findComment-30209
Give him time...OH and better tyres on his Williams :)
he's only been there for a couple of years...he'll come good !!
btw, your 5 year plan sounds good :uh-huh:
I have the house and the GTSt...still working on the GTR :)
https://www.sau.com.au/forums/topic/453-act-roll-call/page/3/#findComment-34479
Guest Zacos
g'day all,
My name is Zacos and I have just recently joined Skylines Australia.
Haven't been able to post anything from work so I probably won't be able to reply straight away!!
Anyway, I drive a Black 1994 R33 GTSt :) and am loving it (need more stomp though)
have seen a few skylines getting about (very nice cars!!!)
Was out at Skyline Performance in Mitchell the other weekend and met joe (top bloke), at least there is now someone in Canberra that knows Skylines!!
looking forward to chatting with y'all soon!
Ciao!!! :) :) :D
https://www.sau.com.au/forums/topic/453-act-roll-call/page/3/#findComment-34956
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
