  • Replies 345
  • 4 weeks later...
Originally posted by CanberraR33
I just started working at Telstra house in Dickson and noticed another R33 in the car park. Just wondering if the owner is on here?! Mine is the silver R33 with the EliteSport sticker on the windscreen.
That's marinko's, the chic in admin drives it there and home.
have you seen the Blue evo 6! droooooooollllll
and the blue my03 sti?
The work carpark at dickson is da bomb :P
  • 3 weeks later...
Hey peoples i am from canberra dont have a skyline as yet will see wha the founds are at around march/april but will hoefully be getting an R33 GTS-T around then. If anyone sees any good ones in canberra for sale around the $17000 - $20000 price pm me please :)
current car is still a nissan though :rolleyes:
BTW: I think I've seen you around Tuggers a few times. Does your SSS have crome mags??
Yea i do live in tuggers but no chrome here i am one of the most anti chrome people you will meet :rolleyes: but yea good chance you will have seen the car. Will have to keep an eye out from now one whenever i pass a skyline :)... though i will admit their is only two i have really seen a bright yellow GTR i think very nice and a white GTS i raced way back in my datto haha well it wasent really a race he took of and i was at the lights still :(
Look forward to meeting some of u
  • 3 weeks later...
You don't want to advertise to crims about what you have in your garage. Imagine some punk getting your plates off the net, then calling you up with "hello it's John Smith from the RTA, are you the owner of a silver Skyline R33 with plates ******? We're doing a customer satisfaction survey, can we ask you a few questions?". They find out when you're not in, etc. and come 'round to help themselves.
That'd be awful!
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
