Yonz Posted January 24, 2015 Share Posted January 24, 2015 I've had this R33 for a little over 1 year, slowly gathering parts and building the engine during that time. During the last couple months I've had some spare time and all the parts ready to go. So it's finally, slowly, coming together. I picked it up in Darwin for 2.5k, and while pretty rough, was a standard manual S1 GTS-T. It came with alot of spares that I've since sold off to fund useful parts. The parts list for it; Haltech plugin pro ECU RB30DET, Spool rods, CP pistpons (20thou oversize), Raw Brokerage oil pump drive, Spool billet oil pump gears, Tomei springs and poncams (R33 25 head). Spool high volume oil sump MetalJacket Balancer GTX35 from Proboost 6Boost manifold, 48mm gate 3.5" cat back exhaust RIPS intake plenum 350Z 6 Speed transmission (CD009). Adapter plate, flywheel and clutch to suit from MA-Motorsports Z Speed Performance concentric slave 350Z Yolk installed onto tailshaft and tailshaft lengthened - waiting for next pay R33 GTR Diff once the standard one dies gktech drop knuckles when a GTR diff goes in Turbosmart FPR 1200 -8AN fuel feed line, -6AN return LS2 coils - coming soon Velo bucket seat + harness Greddy oil relocation thermostat + oil cooler PWR Intercooler Project Mu handbrake shoes Coolant header tank next to brake booster Power Steering cooler and belt Idler gktech front lock knuckles D2 coilovers Still thinking about the majority of the fuel setup. Trimming the fat a bit to recap progress in pics. So going back about a year or so, I started building the 2530. Brass plug removed for VCT mod Internal VCT mod. 2mm down the guts and 1.5mm out the side Oil gallery welded shut New stem seals, valves, Tomei valve springs, lifters and Tomei Poncams Block machined 20thou oversize and a 5mm deep cutout, 15mm in, to clear the exhaust flange No better workshop than your own room All the gear from MA-Motorsports for the 350Z gearbox conversion Bellhousing machined as required for the conversion Adapter plate bolted down And the RB25 automatic bellhousing bolted down With the Z Speed Performance concentric slave installed. Had to drill a few holes for the clutch lines Test fit for clearence, tailshaft measuring and crossmember modding Mounting point is slightly out. The crossmember has already been modded and fits a treat. The shifting position is out by 240mm. gktech should have something to address this soon, hopefully. My return to system from the header tank My effort to save some cash. My $50 beats Ross balancers $330. Power steering belt idler using a subaru timing belt idler, GMB part #JBT658B Engine bay at the moment. The good manifolds will go on once I know the engine doesn't need to come out again. Box out for some minimal tunnel massaging and general tinkering. The 350Z box is actually shorter than all of these. As the old girl sits now. 2 Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/ Share on other sites More sharing options...
Dale FZ1 Posted January 25, 2015 Share Posted January 25, 2015 Really good work there. Interesting approach with the power steer belt idler. Likewise the gearbox - what's the expected benefits from fitting one of those? Keep the pictures coming. Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7467194 Share on other sites More sharing options...
Yonz Posted January 25, 2015 Author Share Posted January 25, 2015 Thanks mate. Yeah, just want to avoid the belt coming off and didn't want to pay through the arse for it. The 4mm alloy might bend eventually but if it does I'll just double the plate up. 6 speed being one benifit (could use a taller diff ratio for close to stock final drive for 1st - 5th and 6th would essentially be overdrive) and it's a stronger box with mostly triple cone synchros throughout it. Shall do Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7467204 Share on other sites More sharing options...
Yonz Posted March 13, 2015 Author Share Posted March 13, 2015 Slow progress is slow. Work has been flat out and the Drift events in Darwin have started up again so I'm back to dividing my spare time and coin Been doing a heap of little things lately Made up a bracket for my LS2 coilpacks to sit in the valley Made up the intercooler mount and an air dam for it Parts came in the mail! Also played around with another set of rocker covers, I drilled out the breather ports and tapped a 7/8 UNF thread (-10AN) to run a 90° fitting as low as I could get to allow for more bonnet clearance. Also the gold looks much better. The coilpack braket almost done with the loom almost done as well The tailshaft has been made up and a few other things are slowly coming together as well 1 Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7496291 Share on other sites More sharing options...
Yonz Posted March 15, 2015 Author Share Posted March 15, 2015 The loom is 100% done now (slightly old pic). I did a continuity check and everything is as it should be, happy days The difference in height between the push in fitting and the male male -10 90° Coilpacks and covers happy in their new home Quick and probably silly question, I want to turn the engine over to get some oil going through it since it's been sitting a while. Would I need to prime between the filter and pump or something to help it out or should I just be able to crank it and get pressure pretty quickly? Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7496723 Share on other sites More sharing options...
DCIEVE Posted March 15, 2015 Share Posted March 15, 2015 If it has run before the pump will be good to go. But to be sure you can pull the plugs and turn it over with the turbo oil feed off to make sure there's oil circulating. I'm enjoying the build by the way, keep the updates coming Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7496764 Share on other sites More sharing options...
Yonz Posted March 15, 2015 Author Share Posted March 15, 2015 It's never ran. Everthing is brand new and only has assembly lube. I figure it should start pumping eventually, but I don't want to have it cranking for a minute and still have no oil pressure because I skipped a step I didn't know about Pulling plugs and the oil feed will be easy enough. Cheers, I'll try to keep them somewhat regular haha 1 Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7496775 Share on other sites More sharing options...
Dose Pipe Sutututu Posted March 15, 2015 Share Posted March 15, 2015 That 350Z conversion is interesting, hopefully there will be a full off the shelf kit one day - seems there's still some mucking around to get it to fit. Would love a 6 speed in my R33! Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7497248 Share on other sites More sharing options...
Yonz Posted March 16, 2015 Author Share Posted March 16, 2015 Thanks mate, can't wait to test it out. There isn't really a great deal of hassle with it, If I had shops nearby and a bit more spare coin it would be sorted out by now. The tailshaft, slave and shifter mount are the only bits that I've had to sort out. The tailshaft is in the post as of this afternoon and the slave is sorted. gktech will have a shifter mount in the coming months, though if I get desperate I can get one from other shops for about $300 The only other aspect that requires thought is the diff ratio. 4.11 is too short for this box, something around 3.5 would be nice I think. Z331st 3.7942nd 2.3243rd 1.6244th 1.2715th 1.0006th 0.794Reverse 3.446R331st 3.3212nd 1.9023rd 1.3084th 1.0005th 0.759Reverse 3.382 Though I picked up a R33 GTR diff the other day and I don't know if I can get such a tall ratio to suit it, which would be unfortunate. Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7497812 Share on other sites More sharing options...
XRATED Posted March 18, 2015 Share Posted March 18, 2015 R200's are in everything Nissan... I'm sure with a little research you could find something close to 3.5/3.7. Cheers J Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7499177 Share on other sites More sharing options...
Yonz Posted June 14, 2015 Author Share Posted June 14, 2015 Been extremely lazy over the last few months, though I've pulled my finger out once again and I'm back at it Haven't had any luck chasing the diff gears I want. 3.583 from a NA Auto R33 would be ideal, no one has any though. Pulled the subframe and got gktech solid bushes for it. The press at work sure came in handy for that, what a pain! Pulled the engine for more access to make the fuel lines and turbo lines, also installed the flywheel and clutch Got all my fuel system goodies and have put most of them in now. Aeromotive A1000 is directly under the surge. That hole punched stainless sits over the pump to at least offer some protection. Opened up the main tank and was not greeted with a pleasant sight. The pump and fuel level were loose and free to float around, both clogged with gunk and the mounts had just about rusted away.Needless to say, I dropped the tank. Lucky I had a spare tank, so after cleaning the spiders and other creatures out of that I took the level out and cleaned it up. This guide came in quite handy New 340LPH pump with -6 lines all the way to the surge and back Since my old tank was going in the bin, I decided to rip out this sensor that is otherwise inaccessible. It connects to the fuel level. Any ideas what it does exactly? Got a heap of parts waiting to go in, so updates should be somewhat regular... hopefully. Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7550322 Share on other sites More sharing options...
KerrodR33 Posted June 16, 2015 Share Posted June 16, 2015 Just read your thread, nice work! I'm in Darwin also so will be keen to see this out and sliding! Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7551404 Share on other sites More sharing options...
Yonz Posted June 16, 2015 Author Share Posted June 16, 2015 Cheers.Awesome, there is quite a few big events coming up soon that you won't want to miss. I can't wait to get it out as well, though in the meantime my Maroon 31 is out there every event 1 Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7551455 Share on other sites More sharing options...
Yonz Posted June 29, 2015 Author Share Posted June 29, 2015 (edited) Made up some brackets to hold the new fuel lines and the old brake and tank breather lines. Cut and drilled some rubber spacers/holders which work quite well. Bent up the hardline and flared the ends, it all sits pretty well I recon (Tek screws on the brackets are temporary while I'm taking everything in and out) Started putting the braid onto the fittings, need to wrap the lines to avoid chaffing. Looks like it will be pretty snug next to the tank. A1000 and Nuke filter are mounted with their nice rubber mounts Got a oil drain for the turbo and head made up. AN fittings were going to be too bulky. Once this fuel system is sorted I've got to finish up the wiring and the interior, fun times ahead. Also, anyone have any idea how to remove a pin/wire from this plug? Edited June 29, 2015 by barbados_26 Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7559053 Share on other sites More sharing options...
Dose Pipe Sutututu Posted June 29, 2015 Share Posted June 29, 2015 ^ pry the grey plastic retainer from the top side (where you see the pins).. then you can use a small jeweler flat head and push down the pins and eventually they will slide out along with the rear seal. Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7559116 Share on other sites More sharing options...
Yonz Posted June 29, 2015 Author Share Posted June 29, 2015 Awesome, thanks for that Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7559167 Share on other sites More sharing options...
R6n350GT Posted October 28, 2015 Share Posted October 28, 2015 update to cd009 to RB ? Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7627835 Share on other sites More sharing options...
Yonz Posted January 21, 2016 Author Share Posted January 21, 2016 R6n350GT Not sure what you mean sorry mate. The box is a cd009 if that's what you're curious about. Super slack at updating this thanks to my computer dying, going to Japan (Ebisu!!) and moving from the NT back to QLD, but the 33 has had steady progress during a busy year. So now that I have a computer and internet again I can resume updates Continuing from where I left off; Finally found a 3.58 diff, I will be throwing a cusco 2 way amongst it soon enough I needed to make up the fuel system wiring, so I mocked this up Luckily I had some spare time at work and was able to throw this together Sitting in the 33 all ready to go Tight fit for the fuel lines, but they clear the tank. -8 feed and -6 return More spare time at work and the rusty battery thingy is sandblasted, keen for a lick of paint gktech LCA's rocked up. It was a bit of a guessing game putting them together, but I got most of it correct after confirming with Greg "The rose joints on these arms have 1" longer threaded section so the rose joint can safely be extended a total of 35mm (really it could probably go even further but we have to stop somewhere)." - Greg from gktech gkteck knuckles were next on the list to assemble, so I ripped apart what I need from the factory knuckles Easy as pie Testing clearance with everything installed and I found I was fouling on the brake bracket, so I cut up some angle and welded them on No more fouling! Got the braided lines fitted up nice throughout the entire range of lock as well I also redone all of the braided lines to the turbo. I forgot to install the heat shield stuff first time around Engine, box and tailshaft all back in the car, hopefully never to come out again. On the ground for the first time in well over a year (Have Cusco coils to go in soon, back is sitting way too low with current coils). Interior back together As she sits now, more or less Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7671034 Share on other sites More sharing options...
eXquiSit Posted January 21, 2016 Share Posted January 21, 2016 nice update! Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7671146 Share on other sites More sharing options...
Yonz Posted May 17, 2016 Author Share Posted May 17, 2016 Slowly been ticking things off the list since the start of the year, the last week has seen a massive jump in progress though... but here is a quick look as to what's happened over the past 5 months. Cold side intercooler piping pieced together Squeezing past the oil cooler Welded together 4" intake and a new UNI Filter CAD airbox Airbox finished, including relocation of the power steering res and adding in a cooler last of the intercooler piping pieced together and welded Starting to tackle the wiring, new injector loom Made a bracket for the Haltech MAP sensor Checking and re-insulating the engine loom, while adding in the Haltech wires for MAP and air temp Cusco 2 way, gktech hicas lockout and whiteline swaybar General underbody shot Whiteline swaybar, offset rack spacers and Cusco coilovers all round (got rid of the D2 coils) Heat wrapped the cold side since it's running so close to the oil relocation and cooler How she sits with all the new suspension bits Making lines for the oil cooler Piecing together the dump pipe leak checking the fuel system And that is up to date as of this afternoon, it's looking pretty close now for the first start! 2 Link to comment https://www.sau.com.au/forums/topic/453076-r33-rb30det-drift-build-in-the-nt-350z-6-speed/#findComment-7728837 Share on other sites More sharing options...
