I've had this problem on virtually every car I've ever owned and never really gotten to the source of it. I've improved it significantly on 1 car (Commodore) by replacing the rims with new ones, but it was still never perfect.
The problem is that at a certain speed (130kph or so on my current car) the steering wobbles slightly when travelling in a straight line. I had new tyres put on about 10000km ago, but surely they don't need rebalancing this often? I would think that if it was wheel balance it would wobble at any speed, not just 130+. I also had the wheels aligned at the same time so I don't think it's alignment either. My tyre wear is fine so I don't think I could get the alignment any better if I tried.
It could still be wheel balance or alignment though, I'm not sure. Other possibilities I thought of include warped rim/rims, worn steering rack, or worn wheel bearings. The gearstick doesn't wobble at all so I've pretty much ruled out an unbalanced tail shaft.
I'm looking at replacing my tyres with better ones within a few months, I'm thinking that at that time I will also send the rims off for a repair/balance in case they need it, and also replace the bearings even though there is no free play at all. Anyone have any other ideas of what it might be?
https://www.sau.com.au/forums/topic/45308-steering-wobble/
don't mean to hijack your thread jim, but i have a similar problem except my streering wheel fully vibrates when under gentle - mid braking. under hard braking it feels fine.
very strange. no idea what is causing it either.
https://www.sau.com.au/forums/topic/45308-steering-wobble/#findComment-924327
Nobody has even mentioned tyre pressure yet :)
You say that you had them balanced 10,000k's ago, that is a long time.
It's quite possible that you've lost one (or more) of the lumps of lead attached to the rims. It's very common for them to just fall off, you only need to take a walk down the street and look in the gutter to see how many bits of lead get thrown off.
myr332 your discs probably need machining.
https://www.sau.com.au/forums/topic/45308-steering-wobble/#findComment-924644
Also think about cleaning the inner rim.
Bit's of clogged up dirt can wreck your balance, acting just like a bit of lead they use to balnce it.
I had a wheel balance once then on the way home a here this clunk on the left wheel.
What the???
Then clunk on the right 10 kms later
Well that was a waste of money.....hehe
https://www.sau.com.au/forums/topic/45308-steering-wobble/#findComment-925467
Does it do this while turning at mid-low speed?
https://www.sau.com.au/forums/topic/45308-steering-wobble/#findComment-925663
I've got new radius rod bushes, via whiteline's suspension kit. The problem was pretty much the same before and after. I did an alignment afterwards. Like with JaseR33, the wobble stops above a certain speed. Seems to only be one "spot" where it happens. Except on my Torana, where it just got worse and worse as the speed went up :)
https://www.sau.com.au/forums/topic/45308-steering-wobble/#findComment-925903
Get a balance.
It doesn't cost much, and if it doesn't fix the problem, then it rules out another possibility.
Almost everyone has said the same thing, and as I mentioned (Birnie's post backs me up) the fact that your last balance was done 10,000k's ago is a good indication that that is all the problem is.
https://www.sau.com.au/forums/topic/45308-steering-wobble/#findComment-925925
1... have the tyres developed any bulges on the sidewalls? this can happen to new or old tyres and this will throw out the balance.
2... have you been getting the wheel balances done at the same place?, some place only balance to the nearest 10 grams, see if they can balance down to 5 grams or so, some car's steering/suspension are more accepting of out of balance wheels and you wont notice it so much and with others it will drive you crazy.
3 ...another imbalance cause can be just that the tyre looses it shape, some tyres are not perfectly round or do not retain their shape perfectly and this can cause the balance to go out as they wear thus needing rebalancing.
you may need to take the tyre guy for a drive, their machines are not likely to show an imbalance if it occurs at 130 km/hr as their machines dont spin that fast - for safety resaons i've been told (in case things fall off).
I nearly always end up getting tyres balanced more than once.
good luck
https://www.sau.com.au/forums/topic/45308-steering-wobble/#findComment-926040
I have a similar problem and in fact have had it since I had the car 2 years ago. When I got the wheels aligned (4 wheel steer alignment) was told that there was "run out" in the front rims - ie slight buckling meaning they are not perfectly round.
Mine does it just above 100kmh but then disappears above 110, also none at lower speeds.
They tried aligning it for ages but couldn't do any more. Solution they tell me is to get wheels repaired or replaced.
I just live it with now
Cheers, Al
https://www.sau.com.au/forums/topic/45308-steering-wobble/#findComment-926162
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
