Fabulous!!!
Better IMO than a GTR. Pity they are so damn hard to get in to Australia.
They've got to be a well balanced bit of gear, far more nimble than any R chassis.
Keep the pics coming, and keep the whale tail.
  • 4 months later...
  • 2 years later...
Update time. Not much done im afraid been busy with houses and stuff. i have just getting some parts for final build up, I managed to get a GTR 4 wheel drive gearbox with conversion to cosworth engine, comes with all driveshafts and gearbox cross member adapted to fit the escort also comes with the attessa pump, wiring and a ETS pro controller system. very cheep in fact. Only problem, its all still in the UK. looking at shipping it over soon.
A pic of the car at the moment, pic was taken a while ago, had a windscreen fitted a while ago and the interior painted all white. When its done hopefully it will look something like the 2nd or 3rd pic.   Or maybe even a different colour
  • Like 2
This is a pic of an escort cosworth with a GTR engine in it. Tight fit and heavy on the front I was told.
Not all the same cars so it looks like a popular conversion for brute power drift style.
Edited by ossie cossie
  • Like 1
  • 4 years later...
  • 1 month later...
2 more pallets of parts arrived at fremantle docks today, one of these contain the 4x4 R32 GTR gearbox, custom front and rear prop shafts ETS pro gearbox controller, Attessa pump relays and hydraulics and 2 converted bellhousings that fit the cosworth engine one on a gearbox and the other is a spare to fit a spare box i have.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
