i've already made this post but wasnt getting much response to im trying posting here.
so i've had my car for about a year now, bought it without aircon and was happy with it but i think i'll be keeping it for a while to come and want to put the air con back in, i want to know whats involved in doing this, parts i need etc. the car currently has the climate control thing and everything on it works, except for the fact there is no actual aircon system in there
Yeah. You got better info in your other thread
My point being is it's not easy. Not even for some people who work on car AC's for a living.
Skylines AC was sophisticated for it's time but it's different from other vehicles
Getting the 2nd hand parts and putting it together . Do they even work? How would you know ?
Then find out some components need replacing. Thermister, receiver dryer, condenser, all the sensors, using correct ohm resistors
There will also be a level of fault finding and rectification once it's together.
I hope you have the AC manual with wiring diagram and fault codes/diagnosis The AC diagnosis will give you good information and point to the issues
But if your not an AC / Auto elec it's going to be a bugger because you need an understanding and be able to trace wiring faults and remedy.
Somethings your better off not doing DIY.
Why do you think i'm posting here if i knew how to do it myself? i asked for a list of parts and wanted to know what's involved in the process, i know its complicated and i never planned on doing the entire thing myself but i wanted to get an idea of what i could get myself and what i could do myself and then once majority of it is done give it to someone who knows what they're doing to finish up all the wiring/little details. If i wanted to simply give my car to someone else to do the entire thing for me and spend a fortune in the process then i wouldnt be on this thread, and yes your initial information was totally useless because i asked for parts and a process and you told me to go do it myself or get someone to do it, please learn how to read and answer a question while using your brain before you write a reply thanks
yet again your info wasnt helpful, i live in qld and theres plenty of places i can get parts nearby, what i asked for in the original post was a list of parts i needed for this, for example what parts i need to get new and what i'll be fine with second hand and whats involved in the whole process, i have gotten a response in my other thread although i'd like more than one source of input just to see if theres anything he missed etc, unless you know whats involved and a list of parts i need or a source with that information then stop wasting my time and get off this post
  • Like 1
No photos posted on what's already in the car so how can anyone give correct advice.
For all we know it might only need a compressor but then again the whole evaporator unit may be missing.
If the evaporator is there, perhaps it's rooted and could be a reason the previous owner ditched the aircon .
Too many unknowns.
im being rude because he was being rude lol, and jiffo maybe people can just ask those questions i can give a response? i dont plan on writing out every single detail of my car and hope some of it is relevant information haha, im assuming the previous owner pulled out the AC because there used to be a big single turbo rb26 in it, and i can provide pictures of the engine bay and all that if needed but from what i can tell nothing on the interior of the firewall has been pulled out just all the engine bay components
So you're saying the evaporator is still in position.
Did previous owner seal the high/low pressure fittings at the firewall? This is vital or contaminants will have entered the system and you'd be spending a lot of time and effort on a blocked TX valve as a minimum.
The engine bay components are the compressor, condenser/filter dryer and the connecting pipework.
There should also be a thermo fan in front of the left side radiator.
None of this is much use though, without the electricals. Hope previous owner left all that intact.
Mounted on the bonnet latch strut should be the ambient air temp. sensor.
In one heater pipe at the firewall should be the coolant temp sensor.
Inside the car on top of the dash should be the sunload sensor.
If the evaporator is untouched its sensors will still be there.
It's a complicated system.
Best chance is to find the complete setup from a 32 half cut.
  • Like 1
so to update i couldnt find any electicals because i wasnt too sure what to look for, the fittings weren't sealed, im fairly sure i found a sunload sensor on the dash and couldnt find the air temp sensor, i'll post some pics as well
Here's some photos from my 32.
The ambient air temp is that cad. plated box and may not be exactly as this one is due to the fitment of a magnificent horn.
The thermo fan can also be seen.
Filter/dryer is attached to the condenser.
High and low pressure fittings at firewall. These are going to cause you a headache as yours were left open to atmosphere.
Suggest you have a talk to an aircon. specialist to see if they can flush your evaporator.
Explain your situation, it's bound to have happened previously.
In fact I gave a mate an under-dash aircon unit for his Statesman way back when. Unit had been kicking around in the dirt for years yet he installed it and the experts made it run fine.
Your electricals will pose problems if they've been hacked off. You may have to strip back the various harnesses to find the remnants of circuits.
awesome, well for starters i'll go get it checked out by an aircon specialist about the evaporator and after that i'll get all the parts i'll need and either install it myself and get all the little things sorted out by a pro or just get someone to install everything in one go
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
