Rb26 Forged Bottom End Short Motor Brand New
For Sale:
RB26 short motor, just been machined and assembled, painted and ready for sale.
Details of build are as follows;
Rb26 R32 Engine Block
Mahle Forged Pistons 86.5mm
Scat H beam Forged Rods
Bored to suit pistons, honed and plateau honed
Acid dipped block
R34 GTR crankshaft, crack checked, linished, grub screwed.
ACL Race series bearings big ends and mains
Blueprinted assembly and all machining done by Arundel Cylinder Heads on the Gold Coast all documents available for serious buyers. All clearances measured and noted.
Can supply additional parts, enquire within (harmonic balancers, oil pump, rear main, crank key ways and pulleys etc)
$4500
Located Gold Coast - Will freight Auswide
0414596256 Johnny - feel free to Call or text any questions you have, please direct questions to my phone as opposed to PM or commenting. More photos available as well.
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
