As far as I know, there is no traction, nor stability control on NM/PNM35s.
You have the awd system, which actively shifts torque front and rear, but there is no individual wheel interaction besides the abs system.
Pm35 models (rwd) have traction control only.
So... What did you cut?
https://www.sau.com.au/forums/topic/453267-vdc-yaw-sensor/#findComment-7469893
What I did was install a switch between the ground line to the yaw sensor/ g sensor. After doing this it feels as the car is rear wheel drive and when it brakes traction the Ecuador des not retard the engine and drop the revs to regain traction you can just keep lighting the tyres up. When the switch is on the 4wd and abs lights come on but abs is still working. Look up 350z VDC off and g35x turn off VDC. Same principleas ours http://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/505135-diy-disabling-vdc.html our VDC looks like this in this pic.
https://www.sau.com.au/forums/topic/453267-vdc-yaw-sensor/#findComment-7469908
You mean it doesn't transfer power to the front, it stays RWD, as would be expected when you cut the G sensor.
Our engines don't retard or drop revs afaik. The V35 does, and it has the TCS light on the dash too.
https://www.sau.com.au/forums/topic/453267-vdc-yaw-sensor/#findComment-7469914
Yeah it seems to be. But it also didn't seem to drop the revs when traction is lost. As in when I plant it from a stand still up my hill it looses traction then revs drop till it is regained. After disabling the g sensor via a switch I can just keep the tyres spinning all the way up the hill.
Your right that it defiantly isn't the same as in the 350z and v35 but still some benefit from adding the switch:)
https://www.sau.com.au/forums/topic/453267-vdc-yaw-sensor/#findComment-7469929
At a guess, it drops rev because the starts sending torque to the front, and starts to create more grip. Now you have just made a rwd. Dunno if it's safe for the awd system or not.
Just for any pnm35 owners looking, all you have to do to make yours rwd safely is remove the fuse in the drivers kick panel.
  • Like 1
https://www.sau.com.au/forums/topic/453267-vdc-yaw-sensor/#findComment-7469973
I looked into this with my Nissan mech mate, seems there are two Attessa computers at least, one of which probably has some traction/stability control. His is an ARX, mine a base model RS and they are different part numbers.
I know Craigs ARX never had traction, or stability control. :P
https://www.sau.com.au/forums/topic/453267-vdc-yaw-sensor/#findComment-7470198
well been driving with it switched off in red mode for the past few days. Seems to be no issues with the Atessa system as it will re engage with no issues when switched off and restarted. So so far seems to be a simple way to alter between awd and RWD ;)
https://www.sau.com.au/forums/topic/453267-vdc-yaw-sensor/#findComment-7470990
That's good.
But what I really meant was there maybe pressure causing damage to the transfer case. I know there is some difference between the systems in the r32 and the 33/34 which means you can flick a switch in the 32, but in later models you can install a switch, but it causes damage to the transfer.
I don't know enough about the clutch packs and pressure to tell you exactly the issue, but I know some cars are effected. Just want to make you aware of it.
https://www.sau.com.au/forums/topic/453267-vdc-yaw-sensor/#findComment-7471010
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
