Just filled up the rb25 silvia ive got and found out its doing over 17L per 100kms. This is just gentle driving around the suburbs, no highway, so that could partially explain it, but its still off the scale.
Would a dyno tune help diagnose the problem?
Possibly oxygen sensor? Is it possible to test the o2 sensor without just buying another and seeing if it works better?
Considering the silvia weighs a couple hundred kilos less than a skyline, fuel consumption should be even better one would assume, so im keen to try and work out what the problem with this is.
91 Silvia Q's with Rb25DET (from '96 R33 afaik)
RB25 gbox
2.5" exhaust
Boxed pod filter
Running 10psi vis bleed valve
FMIC (600x300x65)
https://www.sau.com.au/forums/topic/45327-17l100kms-with-rb25-solution/
ill check the fuel pressure hopefully sometime next week.
as for o2 sensor, ive read different places where you can get cheaper ones (from falcon or something?) that work just as good?
also ill reset the ecu tonight - didnt think of that till now, but it may help?
EL Ford O2 sensor, from petroject cost me $80. The plug is different, as are the pins, so you need to swap them.
I couldnt get the solder to take to the OEM sensor wires, so had to remove the pins from the plug, cut the wires and solder directly to the pins.
Either that or $184 from nissan.
I went from 250ks to a full tank to 350ks odd (i got 380 once) by changing the 02 sensor
its only supposed to last 40,000 ks according to nissan. i had mine replaced at 95,000 (odd) and it was the factory unit still. so i had 55,000 odd ks of a dead o2 sensor and bad fuel economy
the sole purpose of the o2 sensor is to give feedback to the ECU so it can lean out the fuel mixture
Geez, I'm starting to feel a bit better now (I'm not the only one)!!
I presume you're running the standard ECU. I'm running a similar setup to yours in my R33, with the addition of a Microtech LT12.
Up until a couple of weeks ago, I was consuming about 20.5L/100km driving it like a hurse!! Had it in my head that it should be returning more like 11-12L/100km.
Had some fine tuning done on the dyno last week and tonight I've returned 16.1L/100km with quite a few WOT blasts. Am pleasantly relieved that it's improved, but I'm not sure whether I can realistically expect much better at this stage. My car is currently putting out about 165rwkw, so I guess that this rate of consumption is not so unreasonable, it's just not what I'm used to.
However there are blokes out there running much higher outputs and claim to be running better economy than this!? What's the story guys? How is it so?
I definitely thought that a standard ECU would return much better economy than mine as the Microtech doesn't have a "closed loop" circuit to reduce consumption at idle and on steady throttle.
perhaps the dyno tune helped reduce it, but a new o2 sensor may help more?
does consult on the ecu (brother who works at nissan thinks they may have consult computer thingy) tell u much, eg would u be able to tell from it if the o2 sensor is dead?
this is readout from consult. are ECU's made as either MT or AT? if so, i think i may have a AT ecu
ticket reads:
SYSTEM: A/T
DATE: 07/11/2004 17:50:37
P/#: 31036 - 52F00
SELF-DIAG RESULTS
DTC RESULTS
THROTTLE POSI SEN
T/C CLUTCH SOL/V
LINE PRESSURE S/V
OVERRUN CLUTCH S/V
turns out my o2 sensor had short circuited or something internally (resistance ~ 8 ohms), and melted the insultation off one of the wires, then melted the wire.
so guess ill be needing a new o2 sensor
does the EL Ford one fit the same thread? if so does anyone know how it's wired up?
im not sure, it seems that most people are of the opinion that if the ford el sensor (3 wire) fits the thread, then u can use it.
try unscrew urs, then put it back in (not too hard) then go down to repco, unscrew it (bring wet cloth), and take it to the counter and compare it with the el ford one?
btw my fuel consumption is down to 13L/100kms from 15 and 17 last two times i filled, was hoping for less though. i think my ecu might be an auto one so perhaps something to do with that?
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 馃ぃ
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
