Just filled up the rb25 silvia ive got and found out its doing over 17L per 100kms. This is just gentle driving around the suburbs, no highway, so that could partially explain it, but its still off the scale.
Would a dyno tune help diagnose the problem?
Possibly oxygen sensor? Is it possible to test the o2 sensor without just buying another and seeing if it works better?
Considering the silvia weighs a couple hundred kilos less than a skyline, fuel consumption should be even better one would assume, so im keen to try and work out what the problem with this is.
91 Silvia Q's with Rb25DET (from '96 R33 afaik)
RB25 gbox
2.5" exhaust
Boxed pod filter
Running 10psi vis bleed valve
FMIC (600x300x65)
https://www.sau.com.au/forums/topic/45327-17l100kms-with-rb25-solution/
ill check the fuel pressure hopefully sometime next week.
as for o2 sensor, ive read different places where you can get cheaper ones (from falcon or something?) that work just as good?
also ill reset the ecu tonight - didnt think of that till now, but it may help?
EL Ford O2 sensor, from petroject cost me $80. The plug is different, as are the pins, so you need to swap them.
I couldnt get the solder to take to the OEM sensor wires, so had to remove the pins from the plug, cut the wires and solder directly to the pins.
Either that or $184 from nissan.
I went from 250ks to a full tank to 350ks odd (i got 380 once) by changing the 02 sensor
its only supposed to last 40,000 ks according to nissan. i had mine replaced at 95,000 (odd) and it was the factory unit still. so i had 55,000 odd ks of a dead o2 sensor and bad fuel economy
the sole purpose of the o2 sensor is to give feedback to the ECU so it can lean out the fuel mixture
Geez, I'm starting to feel a bit better now (I'm not the only one)!!
I presume you're running the standard ECU. I'm running a similar setup to yours in my R33, with the addition of a Microtech LT12.
Up until a couple of weeks ago, I was consuming about 20.5L/100km driving it like a hurse!! Had it in my head that it should be returning more like 11-12L/100km.
Had some fine tuning done on the dyno last week and tonight I've returned 16.1L/100km with quite a few WOT blasts. Am pleasantly relieved that it's improved, but I'm not sure whether I can realistically expect much better at this stage. My car is currently putting out about 165rwkw, so I guess that this rate of consumption is not so unreasonable, it's just not what I'm used to.
However there are blokes out there running much higher outputs and claim to be running better economy than this!? What's the story guys? How is it so?
I definitely thought that a standard ECU would return much better economy than mine as the Microtech doesn't have a "closed loop" circuit to reduce consumption at idle and on steady throttle.
perhaps the dyno tune helped reduce it, but a new o2 sensor may help more?
does consult on the ecu (brother who works at nissan thinks they may have consult computer thingy) tell u much, eg would u be able to tell from it if the o2 sensor is dead?
this is readout from consult. are ECU's made as either MT or AT? if so, i think i may have a AT ecu
ticket reads:
SYSTEM: A/T
DATE: 07/11/2004 17:50:37
P/#: 31036 - 52F00
SELF-DIAG RESULTS
DTC RESULTS
THROTTLE POSI SEN
T/C CLUTCH SOL/V
LINE PRESSURE S/V
OVERRUN CLUTCH S/V
turns out my o2 sensor had short circuited or something internally (resistance ~ 8 ohms), and melted the insultation off one of the wires, then melted the wire.
so guess ill be needing a new o2 sensor
does the EL Ford one fit the same thread? if so does anyone know how it's wired up?
im not sure, it seems that most people are of the opinion that if the ford el sensor (3 wire) fits the thread, then u can use it.
try unscrew urs, then put it back in (not too hard) then go down to repco, unscrew it (bring wet cloth), and take it to the counter and compare it with the el ford one?
btw my fuel consumption is down to 13L/100kms from 15 and 17 last two times i filled, was hoping for less though. i think my ecu might be an auto one so perhaps something to do with that?
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
