Recently bought an RS260 Autech Stagea, the issue I'm having is that it makes a grinding noise when the car is in gear and clutch pedal is released at the normal rate of speed. If it's released fast, the noise isn't there. It does it in first as well as reverse, and I'm guessing all other gears but you normally release clutch pedal quicker once driving so not really an issue then. It basically sounds like you're trying to put the car in gear without pressing the clutch in first, it's a fast sounding higher pitched noise, like a gear with many smaller, tightly arranged teeth on it. It drives fine and no dash lights apart from the airbag which only came on recently. Also the 4WD fuse was actually pulled out and sitting in an unused slot when I bought the car. 4WD light was lit on dash as well, but after putting the fuse back in it turned off.
BTW, it does not crunch when shifting into gears, that's all fine, just when clutch is engaging at about the half up pedal position.
Edited by r100
I'm not sure, it is quite heavy on the pedal, considering the clutch master has a booster on it as well, it does feel quite hard to press. Doing lower outer ball joints at the moment, I'll see if it's the clutch once it's back on the ground again. Thanks
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
