RB Light Weight Flywheels $375
  • Replies 66
They're a wee bit of a trade off... lose a bit of torque down low, but who the hell cares because you're into the meaty power/torque zones faster, so it's all good. :)
If you really care about torque (as we all really should), do a 3L conversion or put some cams in.
Was talking to my local workshop about a clutch to go with this flywheel today and asked there opinions on a lightened flywheel.
They said they dont install lightened flywheels in their skyline upgrade packages because of the loss of torque, but they didn't say they weren't good.
It just depends on your intended application. They mentioned they are probably more suited to track work, keeping the car in the meaty rev range as you mentioned.
Guest darrinspencer
Flywheels are made and I will be picking up a couple on Thursday the 12.8.04
It is now time to pay. Once you have paided I will pick up your flywheel and post it via Australia post.
To work out your freight charge, have a look at www.auspost.com.au
Allow 7kg in the freight calculator and a sending post code 4009.
Input your delivery post code and it will give you 2 prices for freight. Normal or Express post.
Please deposit $375 and your freight charge that you want to use into my account
Darrin Spencer
NAB
bsb 084223
acc 62 967 4811
Once I have received your payment I will send your flywheel
As I need to pay for the flywheels up front I cannot do COD
Send me a PM with your name and address for postage.
If you want to pick them up if you are in Brisbane, give me a call to arrange a time and place
I will require payment via direct deposit as per the interstaters
For your peace of mind, Post here to say you have paided that way everyone will know.
If you have any other questions give me a call on 0404 075 314
Thanks for the guys that made this happen.
My next group buy I have arranged are CES split dump pipes
Check them out at www.cesracing.com.au
Darrin.
Hi Darrin..I will be making a direct deposit first thing Wed. I will then send you a email confirming my payment as being made. I calculated my postage as $13.00 (normal), so i will be making a deposit of $388.00.
Thanks Darrin
Ken
Forster NSW
Darrin Spencer
NAB
bsb 084223
acc 62 967 4811
Darrin.
Sorry if this is rude, but is there away that when my brother meets you to pickup the flywheel he can pay you cash? Its just $375 is a weeks wage for me and I am not 100% sure about just direct depositing it with a mobile number as security. If a few of the more well known members can vouch for then I am happy. Otherwise I might have to wait till another of the other guys get their flywheels before I will go ahead, sorry I hope this isnt an inconvienience and please dont be offended because this group buy is awesome and I cant wait to get the flywheel.
Evan
Hi Guys, hope this isn't too off topic,
but if anyone has an RB25DET flywheel they want to sell after fitting their shiny new lightweight, please PM me..
preferably in sydney, but will pay postage if it isn't too much
Thanks guys
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
