Can't imagine that they are the same tune file. The AFMs have similar capacity, but the injectors are totally different (25 are 370cc, 20 are 270cc) and there are differences in how the TPS works and so on.
So you really want a 20 file. Have you thought about asking AEMS or (whoever they are)?
I have emailed them and they have indicated they will get back To me. Just thought I'd see if anyone had one that could work ad I'd like to get it running.
From what I can see the p&p units come with the same base setup for the two models.
is it ve based or still pulsewidth ms for fuel tables,
if its ve based, enter all the crap you need into the settings, then just put 100 across the entire map and 15degrees timing and it should be able to make it start from that.
  • 4 weeks later...
