I have sold my GTR so no longer need the parts/spares.
All parts are located in Brisbane south side, and inspections are welcomed, just message me on here or email me and I will try and get back to you as soon as I can.
I will post at buyer's expense, so if you are located elsewhere and if you are interested, please contact me for a quote on freight.
Images are located for all the parts here: http://www.sau.com.au/forums/gallery/album/5783-classifieds-images/
Thank you.
BCNR33 GTR Skyline RB26DETT Camshaft/Timing Covers
One of the camshaft covers has been damaged with a part of it snapped off.
$150
FJ20 Cylinder Head with front cover/oil pump
Bare FJ20 cylinder head
Front Cover with Oil Pump
$500
Trust/Greddy Hard Intercooler Pipes
Only have two of the pipes out of the set of four.
$100 each
Greddy T78 33D Turbo
http://www.trust-power.com/spec_swf/02turbo/Turbo%20Chargers.htm
Split pulse design, rated at 720hp
Removed due to going to a twin turbo setup
$1500
Greddy Type R Wastegate
http://www.trust-power.com/02turbo/waste_gate_valve.html
http://www.trust-power.com/spec_swf/02turbo/GReddy%20%20Waste%20Gate%20%20Valve.htm
$500
Greddy Type R Split Pulse High Mount Exhaust Manifold
http://www.trust-power.com/02turbo/sus_turboex_manifold.html
http://www.trust-power.com/spec_swf/02turbo/Sus.Turbo%20Ex.%20Manifold.htm
Stainless Steel Split pulse design.
$1000
Greddy Heat Shield
http://www.trust-power.com/02turbo/heat_insulator.html
$50
R33 GTR Dash Cluster
Reason for removal was swapped out for an aftermarket cluster.
Has 26,000km on Odometer.
$300
R33 GTR Fuel Pump Controller
$50
R33 GTR YAW Rate Sensor
$100
R33 GTR RB26DETT Alternator
$100
BCNR33 GTR Skyline N1 Centre Triple Gauge Cluster
R33 GTR N1 centre triple gauge cluster
Worked perfectly before being removed from the vehicle
$100
Nissan Skyline GTR RB26DETT Carbon Fibre Timing Belt Cover
Unknown Brand
I impulse bought it when I was in Japan.
$50
Nismo Skyline BCNR33 Series 3 Front under Diffuser
http://www.nismo.co.jp/products/catalogue_2014/#page=265
Genuine Nismo S-Tune aero body kit front under bumper spoiler for the Skyline BCNR33 R33 GTR Nismo S-Tune front bumper.
Paid around $1000 and then realized it wouldn’t fit!
$500
Nissan Skyline BCNR33 GTR N1 RB26DETT Air Box and Snorkel
Nissan Skyline BCNR33 GTR N1 Air Box and Snorkel
K&N Air Filter
$250
RB26DETT Air Flow Meters
These were working fine before being removed from the vehicle, one is genuine and one looks aftermarket.
$100 for the pair
Trust/Greddy 3.7” “Power Extreme” Ceramic Coated Stainless Steel Exhaust with Custom Front/Dump Pipe
Hardly used, was only pulled off due to going back to a twin turbo setup on the car.
Custom made dump/front pipe to suit 4 Bolt turbo exhaust flange. No catalytic converter. :whistling:
$600
KSP Racing Equipment / Attain Carbon Kevlar Rear Bumper Cover to suit Nissan Skyline R33 GTST or GTR
http://www.ksp-eng.co.jp/ATTAIN/exterior/36.html
Brand New still in box
KSP/Attain Brand
Carbon Kevlar
$150
Rasty FRP Boot for Skyline R33 GTR/GTS-T
http://www.rasty.tv/pro/trunk.html
Flat Truck Style painted in QM1 White
Some Cracks in the paint where the wing was mounted.
Very light
$450
R33 GTR Front Lower Arms
Stock R33 GTR Front lower arms with ball joints.
$150 for the pair
Nismo Clear Indicators
Brand New Still in Box.
$80
R33 GTR R200 Competition Diff
Brand New Cusco 2 way Center
Brand New Crown Well and Pinion
Trust/Greddy Extended High Capacity Diff Cover
http://www.trust-power.com/16power_train/diff_cover.html
http://www.trust-power.com/spec_swf/05engine/DiffCover_Up_Grade_Kit.htm
Diff Cover has also been modified to clear a close fitting exhaust
4.11 Ratio
$2000
R32 GTR Dash Speedo
Reason for removal was only due to being swapped out for an aftermarket cluster.
52,000km on Odometer.
$250
R32 GTR Factory Suspension
Inserts and springs.
They were removed while they were still in good working cond.
$400
R33 GTR ABS Unit
Removed from the car only due to installing a pedal box set up.
$250
R33 GTR Washer Bottle and Motors
Very good condition.
$50
R33 GTR RB26DETT Cylinder Head
Complete cylinder head with coil packs.
Was running perfectly and was only pulled off the engine with the intent to build the bottom end, never happened.
$1250
RB26DETT Ind. Throttle Bodies and Plenum.
$400
RB26 Starter Motor
Was working perfectly and was only pulled off the engine.
$100
R33 GTR Sump and Factory Front Diff
$300
  • 1 month later...
  • 1 year later...
