I have sold my GTR so no longer need the parts/spares.
All parts are located in Brisbane south side, and inspections are welcomed, just message me on here or email me and I will try and get back to you as soon as I can.
I will post at buyer's expense, so if you are located elsewhere and if you are interested, please contact me for a quote on freight.
Images are located for all the parts here: http://www.sau.com.au/forums/gallery/album/5783-classifieds-images/
Thank you.
BCNR33 GTR Skyline RB26DETT Camshaft/Timing Covers
One of the camshaft covers has been damaged with a part of it snapped off.
$150
FJ20 Cylinder Head with front cover/oil pump
Bare FJ20 cylinder head
Front Cover with Oil Pump
$500
Trust/Greddy Hard Intercooler Pipes
Only have two of the pipes out of the set of four.
$100 each
Greddy T78 33D Turbo
http://www.trust-power.com/spec_swf/02turbo/Turbo%20Chargers.htm
Split pulse design, rated at 720hp
Removed due to going to a twin turbo setup
$1500
Greddy Type R Wastegate
http://www.trust-power.com/02turbo/waste_gate_valve.html
http://www.trust-power.com/spec_swf/02turbo/GReddy%20%20Waste%20Gate%20%20Valve.htm
$500
Greddy Type R Split Pulse High Mount Exhaust Manifold
http://www.trust-power.com/02turbo/sus_turboex_manifold.html
http://www.trust-power.com/spec_swf/02turbo/Sus.Turbo%20Ex.%20Manifold.htm
Stainless Steel Split pulse design.
$1000
Greddy Heat Shield
http://www.trust-power.com/02turbo/heat_insulator.html
$50
R33 GTR Dash Cluster
Reason for removal was swapped out for an aftermarket cluster.
Has 26,000km on Odometer.
$300
R33 GTR Fuel Pump Controller
$50
R33 GTR YAW Rate Sensor
$100
R33 GTR RB26DETT Alternator
$100
BCNR33 GTR Skyline N1 Centre Triple Gauge Cluster
R33 GTR N1 centre triple gauge cluster
Worked perfectly before being removed from the vehicle
$100
Nissan Skyline GTR RB26DETT Carbon Fibre Timing Belt Cover
Unknown Brand
I impulse bought it when I was in Japan.
$50
Nismo Skyline BCNR33 Series 3 Front under Diffuser
http://www.nismo.co.jp/products/catalogue_2014/#page=265
Genuine Nismo S-Tune aero body kit front under bumper spoiler for the Skyline BCNR33 R33 GTR Nismo S-Tune front bumper.
Paid around $1000 and then realized it wouldn’t fit!
$500
Nissan Skyline BCNR33 GTR N1 RB26DETT Air Box and Snorkel
Nissan Skyline BCNR33 GTR N1 Air Box and Snorkel
K&N Air Filter
$250
RB26DETT Air Flow Meters
These were working fine before being removed from the vehicle, one is genuine and one looks aftermarket.
$100 for the pair
Trust/Greddy 3.7” “Power Extreme” Ceramic Coated Stainless Steel Exhaust with Custom Front/Dump Pipe
Hardly used, was only pulled off due to going back to a twin turbo setup on the car.
Custom made dump/front pipe to suit 4 Bolt turbo exhaust flange. No catalytic converter. :whistling:
$600
KSP Racing Equipment / Attain Carbon Kevlar Rear Bumper Cover to suit Nissan Skyline R33 GTST or GTR
http://www.ksp-eng.co.jp/ATTAIN/exterior/36.html
Brand New still in box
KSP/Attain Brand
Carbon Kevlar
$150
Rasty FRP Boot for Skyline R33 GTR/GTS-T
http://www.rasty.tv/pro/trunk.html
Flat Truck Style painted in QM1 White
Some Cracks in the paint where the wing was mounted.
Very light
$450
R33 GTR Front Lower Arms
Stock R33 GTR Front lower arms with ball joints.
$150 for the pair
Nismo Clear Indicators
Brand New Still in Box.
$80
R33 GTR R200 Competition Diff
Brand New Cusco 2 way Center
Brand New Crown Well and Pinion
Trust/Greddy Extended High Capacity Diff Cover
http://www.trust-power.com/16power_train/diff_cover.html
http://www.trust-power.com/spec_swf/05engine/DiffCover_Up_Grade_Kit.htm
Diff Cover has also been modified to clear a close fitting exhaust
4.11 Ratio
$2000
R32 GTR Dash Speedo
Reason for removal was only due to being swapped out for an aftermarket cluster.
52,000km on Odometer.
$250
R32 GTR Factory Suspension
Inserts and springs.
They were removed while they were still in good working cond.
$400
R33 GTR ABS Unit
Removed from the car only due to installing a pedal box set up.
$250
R33 GTR Washer Bottle and Motors
Very good condition.
$50
R33 GTR RB26DETT Cylinder Head
Complete cylinder head with coil packs.
Was running perfectly and was only pulled off the engine with the intent to build the bottom end, never happened.
$1250
RB26DETT Ind. Throttle Bodies and Plenum.
$400
RB26 Starter Motor
Was working perfectly and was only pulled off the engine.
$100
R33 GTR Sump and Factory Front Diff
$300
  • 1 month later...
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
