I'm importing a 33 that currently got a HKS Fcon V pro with map sensor, and i'm just wondering if they are a total waste of time?  So far i have never heard of any one in Australia being able to tune them.  any ones thoughts?
pick up a navigator as well and you can tune it yourself or with advise from a tuner.
https://www.sau.com.au/forums/topic/45339-hks-fcon-v-pro-qs/#findComment-923767
BD4's, as far as i am aware, have the only english version of the HKS Fcon V Pro software in australia.
There was another guy on the forum that had some jap guys come over with the jap version and tune some cars here, but i think they have left.
Short of doing the same, or going to japan yourself, BD4's in sydney are your only option....that or buy a MoTeC.
https://www.sau.com.au/forums/topic/45339-hks-fcon-v-pro-qs/#findComment-923878
Ring and speak to BD4s, as they have in the past they have issued the software etc to SAS to tune cars,(Dont know if this is a common arrangement though)
So its possible they could lease/lend a workshop in Brisbane the software.... i imagine it would have to be a shop that Paul is familiar with and comfortable with, but can perhaps be arranged.
Bu tlike Steve said, im OZ there are easier/better management avenues.... htough its interestign to note that a majority of the serious Jap streetcars run the HKS F-Con over the Apexi Power Fc.
https://www.sau.com.au/forums/topic/45339-hks-fcon-v-pro-qs/#findComment-924502
ok, from what i have read now, Silverwater Automotive also tune them?
true. but last i knew they just hire the stuff from bd4's. dont know what the go is now.
Software is supposedly in japanese only and you have to be certified by HKS to have access to the software.
true. but the FconV Pro version 3.0 and higher are in english i believe.
-rb25
https://www.sau.com.au/forums/topic/45339-hks-fcon-v-pro-qs/#findComment-931044
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
