RS4S 1999 Dayz Edition
Manual
Yellow
226,000km
Daily driver for my partner since the car was imported in March 2006.
Engine freshened up (4500km ago) with OEM rings, ACL race bearings, hone, full head service, incl.pressure tested, reset valve clearances, OEM headgasket, new OEM timing belt, new ancilliary belts, new OEM water hoses (ie: radiator hoses plus ALL under plenum water hoses (so no nasty surprises from under plenum leaks), new thermostat, new 42mm alloy radiator. Bottom line,the engine is tight, uses no oil and is good to go for another +200,000km.
Modifications:
HKS 2835 ProS 0.68
Poncams 260 Deg Type B
Plazmaman FMIC
Greddy Profec B Spec II
Nistune
3” Straight Through Exhaust including huge rear muffler so uber quiet/stealthy.
Nismo 480cc injectors
Splitfire coilpacks
NPC high clamp organic clutch
HKS pod (also have the OEM airbox which will be included if wanted)
262rwkw (recent dyno print available, conservative tune)
Suspension:
Bilstein shock absorbers (extra circlip grooves for height adjustability)
Whiteline 22mm front and 24mm rear swaybars (new front swaybar links)
Hardrace adjustable castor rods
Hardrace adjustable rear camber arms.
Upgraded Brakes:
R34 GT-t front and rear calipers + DBA rotors
Remsa pads
Sound System:
JVC deck
2x Audison LrX 2.500 amplifiers
Focal splits
2 x Focal 11” subwoofers with custom box
Installed by FHRX Studios with large gauge quality cabling.
Sound deadening in doors.
Extras:
Tow bar, Hayman Reese electric brakes, roof racks, ski racks.
Reason for sale:
Another Inline 6 cylinder turbo on the way so very regretful sale as the car was just freshened up for personal use.
$13,000 located in Sydney.
0407669166 or PM
  • Like 1
https://www.sau.com.au/forums/topic/453433-stagea-rs4s-1999-modified-sydney/
was looking at this the other day the money and passion thats gone into her is unbelievable. just a pity i couldnt get the finance
    • @GTSBoy Yeah i know. The RB20 has 180Nm torque and the gearbox "should" take up to 400Nm if you are not doing stuff like drag/drift or dumping clutch and of course then it is pure "luck" on how will it last. My problem is (i think i said this in different post) that my car was very badly maintain so i would not be suprised if the oil in the gearbox was not changed until i bought it. Yeah the gearbox seem little bit sad.   @Sxnjeet the +T seem very interesting but from where iam from it was nearly "impossible" to done right and not blow twice as money as just swap for the RB25.
    • Hi, I went to the MINES shop here and bought something.. Niikura-San just happened to be there so I managed to take some pics and got him to sign my dash surround thingy. Its still wrapped in plastic back home.. I was thinking how to preserve the signature??? Im sure someones thought of this and done this in the past.
    • Perfect - thanks Joshuaho96!  Will see what I can source.
    • If the plastic wore, the paint will wear quicker. Heck, most car manufacturers cant keep the coatings they put on their buttons/trims alive these days for more than 5 years... A cheap paint won't do it!   However, you can get away with high quality vynil wrap, primarily in areas that won't cop much abuse. Skip colour matching, and just try and wrap a specific area with an edge in a new colour.   PS vynil wrapping is a prick of a job, and I suck at it, even for a small dead flat surface...
    • I think this is more a question you should ask the tuner. My assumption is you have nothing plugged into the original pin for ring gear crankshaft, which is where your map sensor should get wired to, but now you've asked the tuner to disable it. I'm assuming (because I haven't memorised your setup) you are using RB25 ECU on the RB20 loom, to plug into an RB25. You will want to check what else is connected potentially backwards between the engine, loom, and ECU. You might be all fine and safe. The best solution you could have done is wire in a map sensor, and leave the ECU able to read a map sensor.
