RS4S 1999 Dayz Edition
Manual
Yellow
226,000km
Daily driver for my partner since the car was imported in March 2006.
Engine freshened up (4500km ago) with OEM rings, ACL race bearings, hone, full head service, incl.pressure tested, reset valve clearances, OEM headgasket, new OEM timing belt, new ancilliary belts, new OEM water hoses (ie: radiator hoses plus ALL under plenum water hoses (so no nasty surprises from under plenum leaks), new thermostat, new 42mm alloy radiator. Bottom line,the engine is tight, uses no oil and is good to go for another +200,000km.
Modifications:
HKS 2835 ProS 0.68
Poncams 260 Deg Type B
Plazmaman FMIC
Greddy Profec B Spec II
Nistune
3” Straight Through Exhaust including huge rear muffler so uber quiet/stealthy.
Nismo 480cc injectors
Splitfire coilpacks
NPC high clamp organic clutch
HKS pod (also have the OEM airbox which will be included if wanted)
262rwkw (recent dyno print available, conservative tune)
Suspension:
Bilstein shock absorbers (extra circlip grooves for height adjustability)
Whiteline 22mm front and 24mm rear swaybars (new front swaybar links)
Hardrace adjustable castor rods
Hardrace adjustable rear camber arms.
Upgraded Brakes:
R34 GT-t front and rear calipers + DBA rotors
Remsa pads
Sound System:
JVC deck
2x Audison LrX 2.500 amplifiers
Focal splits
2 x Focal 11” subwoofers with custom box
Installed by FHRX Studios with large gauge quality cabling.
Sound deadening in doors.
Extras:
Tow bar, Hayman Reese electric brakes, roof racks, ski racks.
Reason for sale:
Another Inline 6 cylinder turbo on the way so very regretful sale as the car was just freshened up for personal use.
$13,000 located in Sydney.
0407669166 or PM
  • Like 1
https://www.sau.com.au/forums/topic/453433-stagea-rs4s-1999-modified-sydney/
was looking at this the other day the money and passion thats gone into her is unbelievable. just a pity i couldnt get the finance
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
