For Sale: Silver 1992 R32 GTR - 75 500kms running 270hp on wastegate pressure (run in)
Have my r32 up for sale, have owned it for just under a year and had big plans for it but have had a change at heart and want to get out of the car game and travel.
Spent a bit of time and money cleaning it up from when I bought it as I am a very pedantic owner - The mods list includes:
Motor built by Phantom Performance around 5500kms ago
Bored out 20 Thou
Forged oversized pistons
ARP rod bolts
new bearings plus crank re grind
Head is all standard
Oil Cooler
N1 Turbos
Stainless dumps, catco high flow cat to a Motoria Catback
Splitfire coil packs
Kei office Non adjustable coilovers
Almost every bush is polyurethane including Subframe
The steering rack has been rebuilt also, unknown of when
Apexi Intake
4 inch thick FMIC
Slotted rotors fron and rear
MINES Ecu
Air fuel gauge
HI-CAS completely deleted, no lines rack or tierods - adjustable arms in place
Twin Blitz BOVs
N1 Front bar and side skirts
HD Clutch
Some random 18x9.5 rims with 285/30/18 Nankangs
2WD/4WD switch
GReddy air guide
HKS Boost controller (only reading boost at the moment)
Most of which came with the car when I bought it but I have recently fixed up a few little things such as LHF CV boots have been replaced along with the RHF wheel bearing and the HICAS delete. Also have replaced with genuine parts:
Re-badged with all 5 outer badges plus the coilpack valley cover badge
Center aircon vent
LHF inner guard lining
rear window lower mould
Genuine Nissan front wiper blades!!
Had plans for a new ECU and a tune which it would benefit greatly from as the Mines don't work to well in Australia. Receipts for pretty much all work that's been done to the car since import in 05. The car has rego till June and will come with a RWC upon deposit from a genuine buyer. No Swaps - chasing $20 500 but am NEGOTIABLE
PM for more pictures or shoot me a text on 0437 445 706
Located North Brisbane
Edited by Oli_34
https://www.sau.com.au/forums/topic/453460-1992-r32-gtr/
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
