I went to fill the liner up today with Eflex (E70) and the lady at the counter advised me that they would no longer be selling eflex end of
this month. I am disappointed as there arent any uniteds or caltex supporting this fuel in the hills district and blacktown areas.
The lady handed me a paper with the other locations Casula, Moorebank and Drummoyne but they are just too far away.
The only other options for me is United Richmond or Prairevale but they are a little far. I hope United sees this as an opportunity
to maybe supply some of this precious fuel in the hills /blacktown areas
  • Like 1
Think there is a caltex on the highway at giraween that sells it just past fox hills golf club if your heading to the city. But that could be the one your talking about. Its unfortunate.
Maybe if we submit an online petition to United they might see a good business case
to add this fuel to one of their outlets in Sydney West and or NorthWest areas.
This forum has a huge amount of members and if a moderator is looking at this
if we could start a petition. I am sure many SAU members use eflex or e85 and many
are considering to convert to it. Now is the time we need to band together and ask
United that plenty of SAU members will be customers supporting their fuel.
Yeah unfortunately I read an article from Caltex saying they're phasing out E-flex all together. They've already done so in SA but I didn't see any timelines for the other states.
Such a disappointment
That's the same place, Luke - Girraween and Pendle Hill are side by side, so people often mix them up.
There is a United on Fitzwilliam Road in Old Toongabbie that I use regularly, but they've never supplied E-flex. I was considering going E-flex on my car but seeing as it's only available at that Caltex (or was), I never bothered.
eflex is such an inferior fuel to united e85, but i guess its better than running 98 still.
only other option is to buy those 205l drums and just fill up and keep in shed if you drive your car alot, you dont want it sitting around for a long time due to the nature of the fuel.
It would want to be considering the 20+ cents a litre price difference at the moment. E85 is more expensive than E10 at united haha price gouging or what?
It isn't just E85 that's fishy at the Servo up the hill from Emu Plains. Even their pump 98 is suss also I'm afraid.
Agreed; fuel quality (and customer service) has dropped off markedly since new ownership.
Yeah I wouldn't call it inferior. United has been quite shit for a while now in regards to varying ethanol content and clogging fuel filters etc
I have tested both E-Flex and E85 from United.
E-Flex varys between 65-70 Ethanol Content. United @ Prariewood and Minto i get consistant E82-84 and now they finally have the 107 Octane Race Blend which i am currently just filling for the first time now. Price has always been less than E10. Though i do agree United is price gouging, it should be ALOT cheaper.
There are a few things to consider at the pump when you fill up. You can get contamination at ANY servo:
1. How old is the servo?
2. When was the last time the tanks were changed in the ground? How old are the tanks in the ground?
3. How busy is the servo? How long do you think the fuel has been sitting there for?
Last time i was at Minto United i could see the E85 counter was higher than the E10 AND the E98 on the same pump station. That means a good overturn of E85. At Prariewood United, most of the time i go there i have to wait in line to fill up. They only have the 1 pump (Minto has 2) and due to the high concentration of Performance Cars in the Western Sydney area, you can bet it gets a good turnover as well.
All E85 has the properties to f**k your fuel filters / clog your injectors etc. you need to make sure you take a few steps:
1. run E85 compatible injectors which wont corrode
2. run a tank of 98 every now and then to clean out the fuel system and avoid gummy buildup in your fuel system
3. service your fuel pump filters regularly (i run an external inline fuel filter also to make it easier to service)
4. don't let E85 sit in your tank for more than 2 weeks - it makes the fuel go off. make sure you drive the car at least every two weeks, or if the car is going to sit for a long time fill back up with 98.
Easiest thing to do is run a flex fuel kit / tune. That way you can fill up 98 or E85 on the fly without having to run heaps of maps etc. Also helps to have an Ethanol content analyzer in the car (either via ECU or flex fuel kit with a Zeitronix unit)
Edited by BLISTC
  • Like 2
If your fuel goes bad after 2 weeks get a new fuel tank. It's a sealed unit, it can last a few months.
I've been running this stuff for 3 years and do have a flex tune, sensor etc.
Servos ranging from Pendle Hill, casula and Richmond.
Car just finished doing 400kms in 12 months of sitting there. It's just a fuel ur not filling the car with water.
Also the difference between e60 to e85 is marginal at best :)
I run a blend of just over 50% ethanol which keeps fuel more stable has 95% of the detonation resistance properties of e85 and keeps the valve areas better lubricated. And not to mention starts perfectly in winter.
Heres an online calculator i use. Scroll to bottom of page and use the last calculator. It reads in gallons ignore that. Type in how many litres of e85 at approx 82% dial 98 for the pump fuel add your litres and zero out the ethanol in the pump fuel section and you have the blend result http://www.intercepteft.com/calc.html
  • Like 1
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
