  • 2 months later...
Couldn't take the price rise, so I got it retuned back onto 98. Just got it back from Jez, still got a sweet 218rwkw. Will be nice having more than one pump to fill up from :)
What a tight kent! Pay $600 - $800 for a tune to lose power and gain what maybe 3 or 4L/100km? Seems like false ecomomy to me. The money spent on tuning back to 98 would still outweigh your fuel bill ;)
Eflex is still 20c cheaper than E10. I dont care how much it costs i will never use petrol again!
Sell your skyline and buy a VW polo 1.2L of turbo fury and you will get 6-7L/100km in Sydney traffic..
  • Like 4
I was gonna have a Flex Tune done on the Stagea, but that would have meant the expense involved in buying a new computer (it's been running a PFC for about 7 years now) and having it tuned to suit, which was more than it was worth seeing as it's hard to get E-flex fuel on any of the roads that I regularly travel. The Caltex at Girraween would have been closest (and just around the corner from Unigroup too), but I rarely drive through there.
It was a combination of things. Not just the price rise but the being able to just go and fill up where ever I happen to be at the time, makes my life a lot easier, especially since the E85 pump I was using is not as close to me as it used to be since I moved. Jez mentioned that Nistune can do a flex fuel setup now, and that would have been cool, but with needing a timing belt done as well, didn't have the coin, maybe something for the future since he has both my tunes available for me now.
Also, e-flex might be 20c cheaper than E10, but at the United it's more expensive than E10, it costs the same as their regular unleaded.
@pol1on1 the retune was $880, included draining the fuel tank of the E85 that was left over after the drive up there.
Edited by cherring
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
