  On 06/02/2015 at 6:28 AM, BLISTC said:
2. run a tank of 98 every now and then to clean out the fuel system and avoid gummy buildup in your fuel system
How often do you guys fill up a tank of 98 to clean it?
United have very rapidly raised their prices, I have been considering getting my car retuned back onto 98 so I can get some kms per tank again since I'm not seeing prices as low as they used to be at the pump, it's a joke how much they've raised it.
its not really united, its now ethanole is trading on the same market as oil so market price is set along side oil price so varys as much when it shouldnt as its an entirly different economy
http://www.agmrc.org/renewable_energy/ethanol/ethanol-gasoline-crude-oil-and-corn-prices-are-the-relationships-changing/
This sort of explains it, basically instead of being set separately to oil prices all together as it should be the bulk ethanol prices actually is dependent on crude oil prices.
Making it not as cheap as it should be. Can't find the original article I read saying it's now being set the same way the parity pricing agreement with oil works.
From my understanding of ethanol, I wouldn't bother with a tank of 98 to "stop it gumming" as Ethanol is a solvent, which means it will actually clean out the gummy build up, as well as help clear up carbon build ups etc.
No point whining about it, I heard every excuse for not running e85 in Sydney over the years, it's too far away to fill up, Caltex e85 isn't consistent, not enough servo's to run e85 daily...
If more e85 was being sold they would have put more pumps in, end of story. I used to drive 22k's each way to fill up, in the snow with bare feet.
  • Like 1
  On 21/03/2015 at 9:31 AM, SiR_RB said:
They need to open a united servo with e85 in Sutherland shire
Doubt they will until Caltex pull their Eflex from kirrawee. So easy for everyone to fill up there on their way to the nasho
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
