Carbon Fiber Group Buy #2 R32/r33/r34/r35 Evo Etc 2/4/15 New
Starting a group buy #2 for Carbon Fibre \ FRP goods as i have been asked by a few guys we need at least 10+ Buys to get a decent discount
Company called : Wujiang Jianwu we have bought from these guy's before with no issue's
Start Date 4\2\2015 END 4\5\2015 ( I am able to put the order of 10 in whenever )
Seller takes USD
Prices all ALL APPROX might increase \ decrease Slightly depending on our $ and how much items we buy. The More the cheaper. Final Prices will be confirmed after order put through.
Will also confirm prices on shipping after order has been made.
Pick up welcome south western Sydney suburbs.
All items are wet lay carbon or vacuum infused carbon, so its carbon layer on top and FRP base.
R35 GTR
Hood
Spoiler
Hood Vents
Diffuser Blade
Engine Cover Set
Gear shroud centre console
Zele side skirt , Front and rear lip
R34 GTT \ GTR
* R34 GTT cooling panel $110
* R34 GTR OEM rear bumper exhaust shroud - $80
* R34 GTR Nismo front lip - $250
* R34 GTT/GTR wind deflectors - $50
* R34 GT/GTT/GTR passenger headlight intake - $170
* R34 GTR JUN High wing stands - $190
*R34 GTR z tune front bar - $350
*RB26DETT coilpack cover - $120
*R34 eye lids
R34 Door Sill - $130
R34 GTT \ GTR canards 4 Pieces - $130
R34 GTR Oem rear bumper diffuser add on - $220
R34 cf boot
R34 front splitter cf $ 350
R34 Auto select front splitter $370
R33 stuff
* R33 B-Pillar Covers - $100
* R33 GTR rear spoiler end caps with "GTR" logo
* R33 GTR OEM rear bumper exhaust shroud - $70
*R33 eye lids $80
*R33 mirror covers
* R33 GTS/GTST S1 Garage defend style radiator cooling panel (will not fit GTR) $130
* R33 fuse box $120
* R33 wind deflectors $157
* R33 GTR OEM wing blade $180
* R33 GTS/GTST/GTR A-Pillar twin gauge pod suit 52/60mm $150
*R33 GTR front OEM gril (suit GTR only) $150
*R33 GTS/GTST - GTR Style front grill (suit GTS/GTST only) $150
*R33 GTST/GTR Top Secret Style diffuser with universal fitting brackets Type 1 or 2 $470
* R33 GTR/GTS bonnet lip $100
*RB26DETT coilpack cover $130
*RB25DET plug cover $130
R33 Jun Lip $250
R32 stuff
* R32 Dash mount double gauge pod Suit 52/60mm
* R32 GTR radiator cooling panel
* R32 GTS/GTST/GTR wind deflectors
* R32 GTS/GTST/GTR headlight intake
*R32 GTR/GTST mirror cover
*R32 GTST/GTR Top Secret Style diffuser with universal fitting brackets
*R32 GTR OEM front grill
*R32 GTR bonnet lip
*R32 GTR/GTST eye lids
*RB25DET S1 & S2 coilpack cover (has screw fittings for ignitor)
R32 Jun Lip $250
R32 AB Flug Lip $240
S15 stuff
*garage defend style radiator cooling panel
*rear bumper exhaust shield
*vented headlight covers (both left & right)
*mirror covers
S14 stuff
*ABS cover
*vented coil pack cover
*oem coil pack cover
*mirror cover
*eye lids
CT9A - Evo 7/8/9
* evo 7 OEM
* evo 7-9 side skirt add -ons
*evo 8 front bumper canards
*evo 8 radiator cooling panel
*evo 9 OEM rear bumper add on
*evo7-9 rear boot spoiler lip (fits with original spoiler)
*evo 9 varis style rear bumper exhaust shield
*evo7-9 wind deflectors
*evo7-9 eye lids
*evo 7-9 mirror covers
Can also get Fender's, Bonnets, Spoilers, Diffusers etc for most JDM cars.
If you don't see a item on the list let me know and ill find out. I think i can also order in some bride seat's
Longz : R35 varis vents , emblem cover , exhaust shroud , bonnet scoop , front grille , engine cover , center console , top secret front lip , zele side skirts ( yes i am hunting for a r35 )
R33 stuff
Put me down for these please
raj : R34 CF boot is $380 no boot lip's but i can get the 32 one and see how far off it is on my 34 lol and yes B pillar covers $130
jaeyon :
*R32 GTR/GTST mirror cover mirror cover $120
*R32 GTR bonnet lip $120
*rb26 coilpack cover $130
current list :
.:: GimpS-R34 ::. : * R33 GTR OEM rear bumper exhaust shroud - *RB26DETT coilpack cover
i need one if this is the factory one not the carbon fibre one
Edited by samrazor
Samrazor : they are carbon fiber ones.
Supra Mk4 :
1993-1998
TRD Spoiler
2JZ engine cover
Fuse Box Cover
Cooling Panel
Arm Rest Cover
Gauge Pod
Radiator fan cover
interior trim 13 piece set
blitz side skirts
vvti engine cover
Please can I have prices on the following?
TRD Spoiler
2JZ engine cover
Cooling Panel
Can I also have pictures of the below item?
They dont make a 'Top Secret Style' diffuser for the supra do they??
IcedTea : $140
Albo :
TRD Spoiler 3 piece : $370
2jz engine cover : 190
cooling panel : 190
TRD 13 piece interior trim $650
I think you can use the r33 top secret diffuser and modify it to suit the supra lol
current list :
nism26 : R34 wing stands and r34 door sills
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
