Hey Guys,
Currently I have the NITTO INVO 235 40 18 fitted to the Axis Autech factory rims. It's nearing time to replace the tyres and I am looking at going Kumho 245 50 18 on the Axis rims.
Basically the current tyre profile simply makes the wheels look like skateboard wheels, they just don't fill the guards enough and look out of place.
It appears I have plenty of space to play with to accommodate 245 50 size tires.
Wondering what people are running, especially on their M35 Axis rims.
Also recommendations of very highly reputable places to have them fitted, balanced and wheel alignment done. No $hit in the past I've had tyre place leave the wheel nuts hand tightened only, not once, not twice but yes 3 times and across all 4 wheels.
https://www.sau.com.au/forums/topic/453503-tyres-for-my-m35-axis-autech/
245/45/18 is a much better size than the 50 profile you're looking at. The 50 profile will have miles too much sidewall.
As a bonus; it is standard size for VE/VF Commodores, so prices a sensible, and they're easy to get.
It reduces the speedo error from around 9-10% to around 3%, which is also useful.
I'm running 245/45/18 Khumo KU31's and have done for years. They are quiet, wear well, and have good grip; wet and dry.
Any recommendations where to score some KU31's at a good price?
The best advice I can give here is ring around everywhere (or at least everywhere you think you can trust, given the previous problems you've had), and specify the exact size, speed rating and weight details you require.
I'd also recommend Michelin Pilot Sport 3 tyres (if they're within your budget), I have them on my C34 and they're great!
I buy them through a local tyre place, and they will match the Imported price on Australian stock. Which ends up about $200 per tyre fitted/balanced.
I've had both import and Australian delivered; I couldn't tell the difference.
Plenty of places on fleabay will freight them, but do the ring around; most of the time you can find them fitted/balanced locally for within a few dollars of freighting, then trying to get a shop to fit them for you.
The only thing I'd criticise is the asymmetric nature of the MOMO tyre as compared to the KU31.
I tend to get an amount of camber wear on the inside edges of my tyres, and with the KU31's; I can have them flipped on the rims to get more wear from them.
Other than that, they seem to be a good thing.
http://www.sau.com.au/forums/topic/434880-momo-outrun-m3-tyres-has-anyone-tried-these/
Hello,
I had the Toyo Proxes 4 on my AXIS, they were fantastic and importantly had the right load rating, you will find that the AXIS is 630kg where as other mainstream is a bit lower. . 245/40ZR18 97W & 245/45ZR18 100W, if I recall didn't alter the rolling stock diameter too much. .
My 2 cents worth is Toyo Proxes 4 hands down. .
Jules
They go ok Jules.
They're a 300 treadwear; I reckon I get better than 30,000km per set of 4.
I swap them front to rear every 10k and when the inner edges start to wear; I flip them on the rims.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
