Folks, I am trying to confirm if my brother in law has been sold what he needs.
We are in the middle of a brake upgrade on his R31 track car. We are going to R33 GTS-T gear all around (A huge improvement on stock Australian R31 stuff)
He has bought an R33 booster and master cylinder off ebay which was listed as coming from a non ABS R33 GTS-T, but it only has two ports. Can I confirm if the R33 had two ports on the cylinder and a splitter block in the lines be split to the front wheels? The cylinder has what looks like a bias valve cast into the housing, but my sister's S15 looks the same and it has ABS fitted. I was under the impression that ABS cars had two ports and non ABS had three.
I am not all that worried about it is it does prove to be an ABS cylinder with no bias valve as we will just plumb in an adjustable one in the cabin if that is the case. I just need to confirm what he actually has.
Aside from that, does anyone have a part number handy for a seal kit for the BM44? It is in good apparent condition but I would prefer to replace the seals before I put it on the track.
Google'd quickly at work, slow day..
BM44 Seal kit;
Nabco part number KPB2994X
I am also under the impression that the ABS cars only have 2 ports whereas the non ABS have 3, but I'm not confident enough to give you a straight up answer :unsure:
Ta, that is what I thought, it was sold as a non ABS cylinder but Dan who owns the car would not know the difference, the main thing was to get the Japanese booster so that we have the correct bolt pattern. Aus R31 has the master cylinder flange bolts at an angle where Japanese ones are horizontal, going to a JDM booster lets us use bigger master cylinders without as much stuffing around.
No difference to me it being an ABS cylinder, we will just fit an external prop valve in the cabin. It is a track only car so no legality to worry about and it is not going to be set up the same as the donor car so bias tweaks are almost certain to be needed to get the best out of it.
I am seriously looking at a bias box and twin cylinders on my own car so we might even pinch my master cylinder (Bigger again, 17/16" off a Navara) and bias valve to get Dan's car on the track as my car is off-track for a few months for a tidy up.
Edited by Blue
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
