Hey guys, i'm a bit torn.
I'm looking for a RB26DETT car for my next ride and i'm stuck between R33 GTR and a Stagea 260RS.
This is going to be my DAILY and it will have to run a 11 second quarter mile
They use the same engine, most of the same components, both AWD and same power etc.
I was going to go for the R33 for the weight but I found out it's actually not that much of a difference(about 200kg I think). I like that the stagea is very unique and uncommon (sleeper) but the GTR has a sportier look and feel.
Now i understand this is completely personal choice but I wanna see what you guys think!
All opinions and thoughts would be appreciated :)
Here's the link for the poll. fire away!
http://strawpoll.me/3564871
https://www.sau.com.au/forums/topic/453515-r33-gtr-vs-stagea-260rs-autech/
Why dont you create a poll here? :huh:
oh i didn't know i could do that!
I think you should decide what you want and get it. I don't see the point of a poll. Are we deciding what you buy?
Just trying to get some opinions. I'm having a hard time deciding :) what would you get?
Either of them modified to run an 11 is going to be a major pain in the ass to drive daily IMO.
Better off getting one for a weekend toy, and a shitter for the daily grind.
I thought they could run 11s with around 300awkw? Could be wrong.
My R33 GTR ran a 12.3 and had a little bit more in it. It could have squeezed another tenth or two out of it. It was ok to drive around but the clutch made it horrible in traffic.
If you can avoid traffic or get a nicer clutch then you'll be fine with it as a daily.
How much was it worked? Built engine? also how much at wheel power was it pushing at the time?
It has to me be my daily as i can only accommodate 1 car but i'm happy to fall into the 12s.
Not much at all done. Stock turbos, stock engine, just management, boost and some other little bits n pieces. From memory it made 260kw at the wheels.
that's good to know! RB's impress me every day.. what a machine.
$15k stag wagon daily
$15k 33 gtr to mod for the strip.
whats your budget, the compromise trying to do both can be expensive and well a compromise in both directions.
spend $30k (probably less)to buy 2 decent cars
spend another 10-20k (could be heaps less could be heaps more) on the gtr and have a track weapon and dont compromise so much.
Yeah, daily drives would be awesome without traffic! Lol! We all know there are some crappy commutes in Sydney. Can I get a Amen!? M1/2/4/5 all horrible.
Problem as I see it, you have an older car with some suspect reliability depending on whose flung spanners on it in the past. You have something you really can't leave at a train station cause you'll never know if it will be there when you get back, kids will open doors into it and scrape is bumpers in the shopping centres and make you cry.
Having said that, look at a Series 2 C34 manual. The VCT is a positive compared to the 26, you have a much simpler turbo system, chuck a hypergear high flow on it and it'll make good power with the usual upgrades, but won't stand out and be a massive sleeper. Chop plenty of GTRs in that and it'd be a laugh.
  • Like 1
I'd get a Stagea so I can lug my dog around in it (would actually do this if I could sell my R32 GT-R). But since I already have a daily, GT-R all the way!
yeah... don't have money for that :)
Don't get me started on the M2.. OH MY GAAWWWD it sucks.
You've given me a bit to think about.. maybe the rb25det could be a good route for a daily... I'm happy as long as i'm chopping rexys
Yup.. I'm leaning towards the stagea just because it's different and a mad sleeper.
I'd suggest the GTR as a strip/weekender and getting a cheap daily
By modifying the stag to do an 11, you are removing practicality i'd seem to think.. in saying that, my friend recently bought a stag, just the rb25det version and it's very fun to drive and be a passenger, and nobody seems to know what they are when you boost past them lol
The autech stageas still command a higher price than regular C34s. Im not sure the extra money is (only) buying you hardware, you pay for the rare factor.
If you are going to mod a C34 with plenty of cash to spend, you might as well get a cheap chassis then do an RB30 conversion. Stageas need the torque down low.
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
