  • 8 months later...
Na, Jez just told me I can't run high boost like I wanted to.
Just fitted 570's and E-manage , he reckons the stock intercooler is holding it back.
I want to run over 20 psi but it's tuned at 16 as there's high risk of detonation.
219 rwkw though,on a safe tune , that was actually my goal.
It appears there's a fair bit more there if I want it, ... hmmm tempting :yes:
re: slim a/c fan.
Can I get any universal slim fan ?
Supercheap auto...
Any tricks I need to know about this install ?
cheers
Yes, any universal fan is fine.
No tricks; just make sure it's turning the right way.
219 at 16psi? that's good. your mod list? i will meet Jez again later on this month
Edited by YangLIU
So looking at stock front bumper, only has 100mm slot for air to reach the intercooler.
Looking at the height of them they are around 300mm.
I'm thinking the front bumper restricts airflow .
Will the HDI GT2 pro really make a difference with the small air duct ?
Can't seem to find any front spoilers anywhere for M35.
Thinking of cutting a huge area to expose the HDI completely.
Anyone else done this ?
i have GIALLA front bumper and side skirts in white color if you want :)
http://www.hirano-tire.co.jp/gialla2/gialla2-63.html
I will soon have a m35 full aero kit for sale. [emoji6]
i don't think there is much difference if you can DIY with stock bumper for the lower grill. but i'd say aero bumper is much beautiful.
what i am worry about is the big FMIC will block air flow to the poor radiator. i saw the highest temp on stock intercool is 101-102C when hot day then it will go down after the small fan working.
after fit HDI FMIC with 2 thin fan running, i saw 104C degree on hot day and i don't know when will it go down if keep stuck in traffic.
also i will put a big square custom number plate on front bumper to block the lower grill more :rofl2::rofl2:
Edited by YangLIU
My engine temps did not change from running the stock tiny intercooler to running an HDi kit.
Scotty's cooling mod, and a larger capacity radiator will improve the cooling system's ability to shed heat.
IMO; the OEM (quite noisy I agree) is far superior to thermo fans for heat management.
I've run a number of different setups using high capacity fans, and custom made shrouds to ensure efficiency, and nothing works better than the stock Clutch fan.
Dolphin front bar for NM35 is unmatched for airflow.
I did notice an improvement in cooling system performance when I changed from the stock "smiley face" front bar to the Aero Kit front bar.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
