Would you become a contributor of SAU?
102 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
We have started losing money due to a very low advertising climate and need to consider new methods for maintaining the site.
If we were to re-introduce paid contributor plans again, would you be interested?
We're thinking;
  • Yearly 'support' membership
  • Two new-style SAU.com.au stickers (or more?)
  • Ability to edit own posts
  • Increased PM space
  • Removed flood control
  • 'Contributor' bar under username
  • Maybe (!!) access to an un-moderated member area
What do you think?
Let us know via the poll and in the replies.
https://www.sau.com.au/forums/topic/453558-want-to-become-an-sau-contributor/
I'm happy to contribute to a forum that means a lot to me considering it has equally assisted me in many ways over the years.
As long as the contribution is affordable and applied reasonably to the running/maintenance of the website and consequently the number of advertising banners are reduced.
  • Like 3
More than happy to contribute.
Site is beneficial for knowledge, technical info, buy/sell parts, social rants etc....
small banners top and bottom no longer bother me on the PC (part of life on the internet now - no more adds though!)
Serious question. How much does it cost to run a forum board like SAU? Ballpark is fine.
Just the hosting and backups is around $1k per month. Then theres Company costs and taxes, external suppliers we use for things like sending mail etc. Tis expensive. :)
I'm happy to contribute. I've been wanting to for years but the structure hasn't been in place.
I'll contribute in it's current form with the ability to edit posts please! Anything else is bonus.
  • Like 1
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
